Alternative Fuel Vehicles Running biodiesel, E85, Natural Gas, Propane? Chat here!
Does E85 gel in the winter?
Old Jan 25, 2008 | 09:27 AM
rrrrrroger's Avatar
Default Does E85 gel in the winter?
Driving through Minnesota I saw several E85 (ethanol-85%) stations.
Minnesota gets really cold. Does E85 gel in the winter? Any special precautions need to be taken for E85 car?
Old Jan 25, 2008 | 10:55 AM
Tim K's Avatar
Default Re: Does E85 gel in the winter?
I wouldn't think so. After all, ethanol is alcohol and freezes at like -230 degrees F. I can't imagine adding 15% gasoline to it would have any impact.
Old Jan 25, 2008 | 12:11 PM
stevejust's Avatar
You might be thinking of biodiesel, which does have cold weather issues.
As the previous post states, ethanol is the same alcohol in beer. You ever put a beer in the freezer?
Old Jan 25, 2008 | 12:12 PM
livvie's Avatar
i think you are confusing E85 with B85 and B10...which are hard to find. One is alcohol and the other is diesel.
Old Jan 26, 2008 | 06:49 AM
Tim K's Avatar
I have....and it turns into a beer slurpee that foams all over the place when you open it!!! But then again, beer is only 3-5% alcohol in most cases and it is the water in beer that freezes. I think a more accurate comparison would be putting hard liquor in the freezer. Put a bottle of Vodka in the freezer and all you get is cold vodka (and that's only about 40% alcohol. E85 is 85% alcohol and Ethanol has a freezing point of -114C (about -237F).
I agree, you are probably thinking about Diesel or Biodiesel in terms of gelling or thickening.
Old Jan 30, 2008 | 04:49 AM
rrrrrroger's Avatar
Yes I are dummy.
Of course alchohol doesn't gel. Good way to avoid using "additives" to prevent line freeze.. Just use ethanol instead.
Old Jan 30, 2008 | 06:41 AM
Any reason why truckers could not use ethanol to keep air lines from freezing? I watched "ICE ROAD TRUCKERS" last season ( was that filmed in Minnesota? ) and freezing air lines was a big problem. I think they were using methanol, or some form which is poisionous. Ethanol ( in pure form ) isn't.
An "Ice Road" I was on in MN recently.
Had -40 WCF last night.
-John
Old Feb 5, 2008 | 06:38 AM
MiaTurbo's Avatar
It doesn't gel, but it is harder to light up. That's why in the winter E85 is really E70.
Old Feb 5, 2008 | 11:28 AM
About the E70 part... E70 is a possibility... but not a certainty.
-John
Old Feb 5, 2008 | 04:53 PM
spinner's Avatar
What? You're not alluding to weird numbers, now, are you?
