Mileage database -- farthest on a tank
Hi Rammstein:
___The Insight can hold ~ 11.1 gallons without the Vapor recovery tubing being filled or ~ 14.1 gallons with. Honda lists the fuel capacity at just 10.6 gallons …
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
___Good Luck
___Wayne R. Gerdes
No, it won't work. What everyone needs to realize is that 90% of visitors are NOT active like you all are. 90% of visitors will never bother to contact anyone else on these boards and 90% of visitors will not be able to contribute if the website is not automated.
This really is not something I'm willing to compromise on. We can discuss the best method to implement a new feature, but automation is the only way to go. If you doubt me on this, at least take my word that I know what I'm talking about. After all, I have to know something about this type of thing in order to build everything you see from scratch!
What's the point of farthest on a Tank? My old motorhome had close to 150 Gallons of usable fuel and got 8 miles per gallon = 1200 mile range.
Miles/Gallon tells the real story. Yes it is interesting but only if you seperate out each model of vehicle into seperate classes. Prius, Insight, etc. since the tank size for each model is the same. Trying to compare a Prius with my motorhome doesn't compare, nor would it be fair to compare a Prius with an Insight.
my two cents worth.
my two cents worth.
![Roll Eyes (Sarcastic)](https://electricvehicleforums.com/forums/images/smilies/rolleyes.gif)
Hi Douglas:
___Have you seen the mpg’s of the automobiles hitting the record ranges
The two are a match made in heaven!
___Good Luck
___Wayne R. Gerdes
![Wink](https://electricvehicleforums.com/forums/images/smilies/emotikons/wink.gif)
___Good Luck
___Wayne R. Gerdes
