H11 Male Socket Found!
Old 08-03-2008, 08:15 AM
Intrus's Avatar
Professional Hacker
Default H11 Male Socket Found!
Just a heads up for others wanting a cleaner HID install. I've found H11 Male connectors! www.innovativewiring.com has them. These are so you can plug directly into the OEM H11 socket without having to splice or have pins stuck into the stock socket.
Old 08-03-2008, 08:24 AM
tharvey's Avatar
Wink Re: H11 Male Socket Found!
thanks for the information, the kit I got came with an 18" extension for this to connect the ballast to the previous headlight although the wiring was reversed, I can now see I can remove the pins and re-insert them in the correct slot
tim
surfer1966
05-17-2012 05:51 AM
blktoy
10-20-2008 10:28 AM
2009CAM
05-03-2008 05:11 AM
pagemap
02-10-2008 10:02 PM
rjm
04-11-2007 03:10 AM
Quick Reply: H11 Male Socket Found!
