CVT Technical Bulletin
I noted on the CVT tranny fluid thread the issue I had with the CVT lurching and slipping after the fluid change.
My dealer told me there is a technical bulletin regarding this and is replacing the clutch pack in the tranny.
Anyone else run across this issue?
I have a 2006 with 31K miles.
Re: CVT Technical Bulletin
Also, what is your car's build date?
I'll see what I can dig up.
Cheers;
MSantos
In another thread, Brian mentioned this was due to a new type of oil that Honda swiched to in July. Are you aware of this oil switch for the CVT, Msantos. H
Not at all Harold.
Honda formulated the HATF CVT fluid specifically for the HCH-II so it is pretty unique amount all CVT fluids. I am definitely not aware of any changes or even a need (cases or incidents) that forced them to change the initial formulation.
This is pretty weird. I'll look into this ASAP.
Cheers;
MSantos
Cheers;
MSantos
cephraim
12
07-30-2008 07:14 PM
