Research Assistance Requested
The Hybrid Lineup is a bit out of date... it doesn't include the Accord or Escape. Is there anyone who would be willing to find the necessary information so that I can update the page? I'm having trouble finding the time right now... and the motivation
Thanks in advance!
Thanks in advance!
I'll help out Jason. I will do the Ford Escape Hybrid thing if someone else will do the other. Give me about a week.
Jason - Let us know what format you want and perhaps it is important to reference by website or source from where each piece of information came.
Mike
Mike
I don't think it's necessary to reference a single source, as the information is simply fact and is likely distributed across many sources already. No specific format... just look at the table and find out what value goes in each box. For the Escape, I think it will have to be broken down into 2WD vs. 4WD instead of Manual vs. CVT/Auto.
Hi Jason:
___I will take the AH if no one has already passed you the specs. I will PM them to you tomorrow.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
___Good Luck
___Wayne R. Gerdes
Hi Jason:
___That wasn’t too bad … I had to take some liberty w/ both GHG emissions @ 15K and Min Charge 0 - 60 performance.
___The GHG Emissions came from the 03/04 Toyota Corolla w/ Auto given its 29/38 EPA rating and 5.9 Tons released. With the AH’s 29/37, I just added .2 tons to the Corolla total.
___The Min charge performance was based off the std. Accord’s 240 HP to 60 plus .2 seconds for the added weight of the AH.
___Good Luck
___Wayne R. Gerdes
Code:
General: Accord Hybrid Manufacturer: Honda Comparison Year: 2005 Available Years: 2005 Base MSRP: $29,990 w/ NAVI: $31,990 Style: Midsize Sedan Seats: 5 Doors: 4 Emissions rating: ULEV-II Emissions @ 15K mi.: ~ 6.1 Tons 5-Speed Auto: 29/37 Actual Mileage: TBD Maximum Charge: 6.7 sec Min Charge: ~ 7.5 sec Net Power: 255 HP@6,000 RPM Engine Power: 240 HP@6,250 RPM Motor Power: 16 HP@840 RPM Net Torque: 232 Ft-Lb’s@5,000 RPM Engine Torque: 212 Ft-Lb’s@5,000 RPM Motor Torque: 100 Ft-Lb’s@840 RPM/20 Ft-Lb’s@5,000 RPM Voltage: 144 V Displacement: 3.0 L Climate Control: Dual Auto Electric Climate Control: Yes PW: Yes PW after S/D: Yes - 4 Window power down from Key FOB Cruise: Yes Remote Trunk Release: Yes Seat Height Adj.: Yes - Leather - Heated/Drivers seat 8-way Power adj. Keyless Entry: No & Start GPS NAV: Optional DD Elements: Yes Home Link Auto: No - Simple Homelink Dimming Mirror Radio: Yes - 120 W/6 speaker and XM CD Player: Yes CD Changer: Yes - 6 disc in dash Tape Deck: No HID Headlamps: No Dual Front Air Bags: Yes Side & Curtain Air Bags: Yes Anti-lock Brakes: Yes Security Alarm: Yes Traction Control: Yes Stability Control: No Turning Diameter: 36.1 ft Gasoline type: Regular Unleaded Tank Size: 17.1 gal Drag Cd: .29
___Wayne R. Gerdes
Hi Jason:
___There are so many to add and the same could probably be said of all the Hybrid’s in their own particular sort of way. I will give you an AH spec run down in a few minutes as that is a lot to type
___Good Luck
___Wayne R. Gerdes
___Good Luck
___Wayne R. Gerdes
Hi Jason:
___I did not see an external Temperature Indicator in the list but it comes with all Leather equipped Accord’s so I believe Honda might have left it out of the AH’s Brochure? I skipped some of the small details from the spec page as they were either redundant or unimportant. Unless you wanted to write up its exterior length, width, height, etc.
2005 Honda Accord Hybrid
Engineering
Engine Type V6
Engine Block/Cylinder Aluminum
Bore and Stroke 86mmx86mm
Compression ratio 10.0:1
Valve Train 24 Valve SOHC i-Vtec
Multi-point FI
Throttle by wire
Variable Cylinder Management (VCM)
Active Control Engine Mount System (ACM)
Active Noise Cancellation (ANC)
Direct Ignition w/ Immobilizer
Tune Up Interval 105,000 miles
Transmission
Compact 5-speed Automatic
Electric Power Storage
NiMH Battery
Rated Capacity 6.0 Ah
Body/Suspension/Chassis
Double Wishbone Front Suspension
Five-link Double Wishbone Rear Suspension
Stabilizer Bar (mm front/rear) 25.4/13.0
Electric Power-Assisted Rack-and-Pinion Steering (EPS)
Steering wheel Turns, Lock to Lock: 2.93
Steering Ratio 14.96
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes
Wheels 16” Lightweight Alloy
All-Season Tires P215/60R16
Exterior Measurements
Wheelbase 107.9
Track (in., front/rear) 61.1/61.2
Curb Weight 3,501 lb’s
Interior Measurements
Headroom (in., front/rear) 40.4/38.5
Legroom (in., front/rear) 42.6/36.8
Shoulder Room (in., front/rear) 56.9/56.1
Hiproom (in., front/rear) 54.6/53.5
Cargo Volume (cu. ft.) 11.0
Passenger Volume (cu. ft.) 102.7
Capacities
Crankcase (qt.) 5.3
Coolant System (qt.) 8.4
Fuel (gal) 17.1
Required Fuel Regular Unleaded
Safety
3-Point Seat Belts at All Seating Positions
Front 3-Point Seat Belts with Automatic Tensioning System
Adjustable Front Seatbelt Anchors
Dual-Stage, Dual-Threshold Front Air Bags (SRS)
Front Side Airbags with Passenger-Side Occupant Position Detection System (OPDS)
Side Air Curtains
Anti-Lock Braking System (ABS)
Electronic Brake Distribution System (EBD)
Traction Control System (TCS)
Side-Impact Door Beams
Lower Anchors and Tethers for Children (LATCH) (rear) outboard
Rear-Center Child-Seat Tether Anchor
Child-Proof Rear Door Locks
Immobilizer Theft-Deterrent System
Exterior Features
Alloy Wheels 16” Lightweight Alloy
Security System
Remote Entry System with Power Window Control
Variable Intermittent Windshield Wipers
Rear Decklid Spoiler
Multi-Reflector Halogen Headlights
Body-Colored Dual Power Mirrors
Body-Colored Body Side Molding
Body-Colored Door Handles
Body-Colored Impact Absorbing Bumpers
Chrome Window Trim
Comfort and Convenience
Dual-Zone Auto Climate Control System
Honda Satellite-Linked Navigation System with Voice Recognition Optional
Power Windows with Auto-Up/Down Driver’s Window
Illuminated Power Window Switches
Power Door Locks
Cruise Control
Leather-Wrapped Steering Wheel
Illuminated Steering Wheel-Mounted Controls
Tilt and Telescopic Steering Column
Home Link Remote System
Premium Interior Accents
Center Console with Sliding Armrest and Storage Compartments
Beverage Holders, Front and Rear (8 total)
Driver’s and Front Passenger’s Illuminated Vanity Mirrors
Ambient Console Lighting
Sunglass Holder
12-Volt Power Outlets (2-Total)
Lockable Glove Compartment with Light
Remote Fuel Filler Door Release
Remote Trunk Release with Lock
Rear Window Defroster
Floor Mats
Side Door Pockets with Integrated Beverage Holder, Front and Rear
Seating
Leather-Trimmed Seats and Door-Panel Inserts
Heated Front Seats
Driver’s Seat with 8-Way Power Adjustments
Instrumentation
Progressive Self-Illuminating Gauges
Tachometer
Idle-Stop Indicator Light
IMA Charge and Assist Indicators
Battery Charge Indicator
Digital Odometer and Digital Trip Meters (2)
Door-/Trunk-Open Indicator Light
Fuel and Coolant Temperature Gauges
Low-Oil-Pressure and Low-Brake-Fluid Indicator Lights
___Good Luck
___Wayne R. Gerdes
Engineering
Engine Type V6
Multi-point FI
Throttle by wire
Transmission
NiMH Battery
Wheelbase 107.9
Capacities
Crankcase (qt.) 5.3
Fuel (gal) 17.1
Safety
Side Air Curtains
Exterior Features
Security System
Chrome Window Trim
Power Door Locks
Cruise Control
Sunglass Holder
Floor Mats
Seating
Heated Front Seats
Instrumentation
Tachometer
___Good Luck
___Wayne R. Gerdes
Believe the only factory option is the navigation system. There are the typical range of dealer options - mats, cargo net, cassette player, wheel locks, auto-dimming mirror with compass. Homelink is standard, but located in small panel with map lights overhead.
An external temperature gauge is included - it alternates on the display with the odometer.
Hi Extex:
___That is good to know as I remember seeing the temperature indicator in the std. Honda Accord EX-L’s and EX-L’s w/ NAVI before and I could not imagine Honda taking that information away from an AH owner. There are usually small items not in the brochures that you might find and add as well. As an example, the Ranger XLT had a 4-pin wiring harness for towing and an engine block heater not listed in the brochure. If you see anything like that, please post to this thread at your earliest convenience.
___Good Luck
___Wayne R. Gerdes
___Good Luck
___Wayne R. Gerdes
