Fake data, strange user?
Fake data... strange
I don't mean to be overly concerned, it may well be a mistake or confusion, I'm not saying it's on purpose, but there seems to be a user with 3 cars, same name, 1 tank each as override and one of them oddly low...
https://www.greenhybrid.com/discuss/...hp?userid=1965
Makes the graph look really bad for the Prius II
Re: Fake data, strange user?
You're right. Interesting. I'm going to remove those cars and contact the member. Here's the info for reference:
Quicksilver ('05 Toyota Prius II)
300 miles @ 42.4 MPG
300 miles @ 7.1 MPG
300 miles @ 7.1 MPG
Hi Jason:
___While you are at it, check out poyntesm’s 2004 Toyota MR2 named Red Roster. 222 mpg after 2 miles is a bit much I E-Mailed him a few weeks ago when it first appeared but he did not fix or remove it. Kindly help him remove it please.
___Thanks in advance.
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
___Wayne R. Gerdes
Hi Lakedude:
___I bet he botched the data entry and meant to put in 47.1 mpg? The 300 miles tank after tank looks odd however …
___Good Luck
___Wayne R. Gerdes
___Good Luck
___Wayne R. Gerdes
I did the best I could in trying to puzzle out the meaning of your prompts, which are far from self explanitory. I had no clue that I was making three separate entries, but rather was attempting to correct mistakes. My data are not fake. I will make one more try to enter the data, while suggesting that you try to provide clearer instruction in how to do so.
Paul Jepperson
Paul Jepperson
Paul, database instructions are definitely on my "todo" list for the next few weeks before I go to college. My apologies.
What you'll want to do is first add a car via the Edit your Cars/Tanks page. After you've created your car, fill out the form on the Add New Tank page for each tank. The system will do the rest.
Paul, here are the records for what you did the last time around. If you need any more assistance on the second try, let me know.
Paul Jepperson updated car on July 19, 2005 at 7:36 PM EST
Paul Jepperson updated car on July 19, 2005 at 7:34 PM EST
Paul Jepperson added car on July 19, 2005 at 7:27 PM EST
Paul Jepperson added car on July 19, 2005 at 7:25 PM EST
Paul Jepperson added car on July 19, 2005 at 7:22 PM EST
Paul, you've now added a car with a lifetime mileage override. Any supplemental tanks you add will not be calculated in. I suggest you remove this "optional" information and then add a tank via the Add New Tank page.
