Website Questions & Input Suggestions and inquiries about Electric Vehicle Forums are welcome here.
extended page load times
Old Jan 8, 2007 | 08:26 AM
Tim K's Avatar
Default extended page load times
Is everyone experiencing these LOOOOONG load times for pages on the GH forums? I tried them in Firefox and IE and from two different locations with two different types of acces and have the same results. I think it might be the advertising slowing things down because it almost always says "ads.doubleclick.com" in the status bar at the bottom of the browser window. I think that the webmaster should take a look at this because it is sometimes to the point where I just give up and leave the site altogether. I think there is a way (in the coding) to instruct browsers to load certain content first without waiting for slower loading items but I don't recall.
Old Jan 8, 2007 | 01:17 PM
Jason's Avatar
Site Founder
Default Re: extended page load times
I haven't experienced this myself, but it's quite possible. I'll pass the word along to CarsDirect so they may resolve the issue if possible.
Old Jan 8, 2007 | 05:58 PM
ibrands's Avatar
Question Re: extended page load times
I haven't encountered any errors, myself. I tried in both IE and Firefox, as well. How fast is your CPU running? If this continues to be a problem for you, please let me know, but I don’t think the ads are creating any problems.
Old Jan 8, 2007 | 08:25 PM
Tim K's Avatar
Since I've tried it on 3 different computers on two different types of connections in two different locations, I'd say its not my PC.
I don't get errors....just real long load times for forum pages.
Old Jan 10, 2007 | 05:43 AM
bwilson4web's Avatar
Engineering first
Start with a traceroute from your machine(s) to GreenHybrid.com to map out the hops. Often you'll find which hop(s) add delay times. Then do a traceroute to a 'fast' web site. You can then eliminate all shared hops.
Bob Wilson
Old Jan 10, 2007 | 07:56 AM
WaltPA's Avatar
Have you tried turning off (unchecking) Show Signatures, Show Avatars, and Show Images ??
Old Jan 10, 2007 | 11:11 AM
Tim K's Avatar
Walt, it is not only within threads that I see the delays so signatures and avatars aren't the problem. Pinging GH gives me much slower responses than other sites do. I ran a couple of traceroutes and here are the results....don't know what I can do about it, but it seems pretty clear where the slowdowns are.
Tracing route to greenhybrid.com [207.212.172.168]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms c-68-84-220-189.hsd1.pa.comcast.net [XXXXXXXXXXX]
2 * * * Request timed out.
3 8 ms 9 ms 9 ms ge-6-2-ur01.columbusblvd.pa.panjde.comcast.net [68.86.213.169]
4 10 ms 9 ms 9 ms po-10-ur01.greenwayave.pa.panjde.comcast.net [68.86.208.53]
5 9 ms 9 ms 9 ms po-20-ar01.wallingford.pa.panjde.comcast.net [68.86.208.49]
6 9 ms 20 ms 10 ms po-90-ar01.audubon.nj.panjde.comcast.net [68.86.208.25]
7 13 ms 13 ms 14 ms po-90-ar01.plainfield.nj.panjde.comcast.net [68.86.208.1]
8 16 ms 16 ms 16 ms 68.86.90.37
9 14 ms 13 ms 14 ms te-3-1.car1.NewYork1.Level3.net [4.71.172.109]
10 15 ms 13 ms 14 ms ae-12-51.car2.NewYork1.Level3.net [4.68.97.21]
11 15 ms 13 ms 13 ms te-4-4.wch010.nycmny2.Level3.net [4.68.110.18]
12 15 ms 13 ms 14 ms 64.200.249.153
13 35 ms 35 ms 35 ms brvwil1wcx3-pos0-0-oc192.wcg.net [64.200.240.253]
14 66 ms 66 ms 67 ms dnvrco1wcx3-pos13-0-oc192.wcg.net [64.200.240.121]
15 66 ms 67 ms 69 ms dnvrco1wcx2-pos3-0-oc192.wcg.net [64.200.106.37]
16 95 ms 92 ms 93 ms anhmca1wcx3-pos12-0-oc192.wcg.net [64.200.240.249]
17 93 ms 95 ms 95 ms 64.200.140.154
18 93 ms 93 ms 95 ms lsanca1wch1-us-telepacific-8-11.wcg.net [64.200.200.62]
19 96 ms 95 ms 95 ms gi51.cr1.lsanca.telepacific.net [64.60.175.237]
20 96 ms 95 ms 95 ms fa00.br4.lsanca.telepacific.net [64.60.224.13]
21 83 ms 83 ms 85 ms 207.212.172.2
22 84 ms 86 ms 83 ms www.greenhybrid.com [207.212.172.168]
Trace complete.
Tracing route to escape-central.com [66.70.135.42]
1 1 ms 1 ms 1 ms c-68-84-220-189.hsd1.pa.comcast.net [XXXXXXXXXX]
4 8 ms 9 ms 9 ms po-10-ur01.greenwayave.pa.panjde.comcast.net [68.86.208.53]
5 8 ms 9 ms 9 ms po-20-ar01.wallingford.pa.panjde.comcast.net [68.86.208.49]
6 11 ms 10 ms 9 ms po-90-ar01.audubon.nj.panjde.comcast.net [68.86.208.25]
8 14 ms 13 ms 14 ms 68.86.90.37
9 13 ms 13 ms 18 ms te-3-2.car1.NewYork1.Level3.net [4.71.172.113]
10 14 ms 14 ms 14 ms ae-1-51.bbr1.NewYork1.Level3.net [4.68.97.1]
11 16 ms 16 ms 16 ms so-0-1-0.mp1.Stamford1.Level3.net [64.159.0.85]
12 17 ms 16 ms 16 ms so-11-0.hsa2.Stamford1.Level3.net [4.68.124.102]
13 16 ms 16 ms 16 ms 4.79.128.14
14 17 ms 16 ms 16 ms escape-central.com [66.70.135.42]
Trace complete.
Tracing route to google.com [64.233.187.99]
3 9 ms 8 ms 9 ms ge-6-2-ur01.columbusblvd.pa.panjde.comcast.net [68.86.213.169]
6 11 ms 9 ms 9 ms po-90-ar01.audubon.nj.panjde.comcast.net [68.86.208.25]
7 13 ms 14 ms 14 ms po-90-ar01.plainfield.nj.panjde.comcast.net [68.86.208.1]
8 14 ms 14 ms 14 ms 68.86.90.37
9 13 ms 14 ms 14 ms te-9-4.car1.NewYork1.Level3.net [4.71.172.121]
10 76 ms 16 ms 21 ms ae-1-51.bbr1.NewYork1.Level3.net [4.68.97.1]
11 19 ms 18 ms 19 ms as-3-0.bbr1.Washington1.Level3.net [64.159.3.254]
12 19 ms 19 ms 18 ms ae-11-51.car1.Washington1.Level3.net [4.68.121.18]
13 18 ms 18 ms 19 ms GOOGLE-INC.car1.Level3.net [4.79.228.38]
14 33 ms 32 ms 33 ms 72.14.238.136
15 35 ms 35 ms 34 ms 72.14.236.15
16 35 ms 34 ms 37 ms 216.239.49.222
17 35 ms 32 ms 34 ms 64.233.187.99
Trace complete.
Old Jan 10, 2007 | 12:21 PM
ibrands's Avatar
Post Re: extended page load times
The ads are set up such that the content loads first, not the ads. We're trying different trafficking measures on our end here, to see if we can remedy this. Let me know if you experience any further issues with this.
Old Jan 12, 2007 | 07:46 AM
Tim K's Avatar
I think you ought to check that coding, or maybe try running the site without the ads briefly to see if that helps. They are definitely slowing the loading of pages.
In addition, I noticed in the IE status bar that while the ads are loading, the message flashes a couple of times that says "a bad URL ads.doubleclick.net" before displaying "waiting for ads.doubleclick.net".
Also, in IE it is very clear that the content is NOT loading first as the top of the pages load....then there is a delay as the banner ad loads. Again, I am seeing the words "waiting for ads.doublick.net etc appear in the status bar at the bottom of the browser before the main content loads, then the sidebar ad (again with the "waiting" message in the status bar), then the bottom of the pages load.
I started using IE for this site as it has gotten unbearable in Firefox. I find the site freezing up my browser, making me unable to access other tabs that are open, unable to right click on anything to open a menu, and often freezing the whole browser to the point where I have to go into task manager and end the task.
Old Jan 12, 2007 | 12:47 PM
Johnc73's Avatar
I only have problems loading this site up in the linux version of Firefox. Windows is fine. I thinks my problem is Flash, the whole browser feels like molasses and I have to switch to a different app to get the image to refresh.
