Use up the excessive charge during a long downhill
Old Mar 30, 2014 | 12:09 AM
nachochip's Avatar
Default Use up the excessive charge during a long downhill
Hello,
I would like to know how can I prevent the traction battery get fully charged easily while a long downhill trip. I know that the traction battery is directly power the A/C system, I guess I can turn my A/C on while a long downhill, but is there any other way I can use up those excessive charge from the brake system? Thanks!
Old Oct 23, 2014 | 05:57 AM
Mendel Leisk's Avatar
Default Re: Use up the excessive charge during a long downhill
Shift into B. That's really the sole reason for that "gear" choice. It'll raise engine RPM, cause engine braking. You can switch back and forth between D & B if revs run up too high. If you do nothing the car's computer will invoke a bit of B anyway. But switching to B does a bit more I think.
Curated Content Editor
Dec 10, 2014 11:00 AM
Billyk
Jan 20, 2008 05:14 PM
Sungod18
Sep 13, 2007 08:52 AM
SoopahMan
Nov 8, 2006 01:25 AM
bilbro
Apr 6, 2006 08:12 PM
