Tire pressure caps -- worked!
Hi,
Yesterday, I noticed one of my tire pressure caps was showing some yellow. Today, I measured it and found it at 35 psi. I topped it off at 40 psi and all four wheels are showing 'green.' The four, 40 psi caps cost $6.00 and $5.00 for shipping, $11 total. Still it is a cheap and easy way to monitor tire pressure. Bob Wilson |
Re: Tire pressure caps -- worked!
Where did you order them from? The only ones I've seen online are at least $10, if not more.
Bob Wilson |
I guess they are better than not ever checking your tires. I find that they tend to not work as well over time.
The big advantage is checking is easy . . . just walk around the car or look at them when you approach the car. Bob Wilson |
Bob-- what site did you order the caps from?
Steve |
Ok... so those of you that have never heard of google... air pressure valve cap....
try: http://www.autogeek.net/kwtc.html or http://www.customwheelweights.com/st...gory_Code=tmmk |
Steve www.ebay.com search for item: 8059554408. Good luck! Bob Wilson |
| All times are GMT -7. The time now is 07:36 AM. |
