recommended mods
Old May 8, 2008 | 05:17 AM
prius12306's Avatar
Default recommended mods
I am picking my 2008 with pkg #3 next week. I am wondering what mods (that do not void the warranty) I should look into. I purchased the hood for the MFD last night as it looked good and I do think glare might be an issue on the display. I'm also thinking of sticking my garmin C550 to the flat top of the hood. Anyone have any recommendations? The shark fin antenna looks cool but I'm worried it might void something. Also, anyone using garmin GPS - where do you stick it - there is not much flat space on the dash. Any help appreciated.
Old May 8, 2008 | 08:56 AM
bwilson4web's Avatar
Engineering first
Default Re: recommended mods
Start with the Prius FAQ to make sure you're optimized for performance. Don't worry about the 'dealer tank' but treat it as 'practice gas.' When you get low, fill up with something like Shell or other high energy gasolines. If you are in an ethanol area, check out the thread about E30 testing.
GOOD LUCK!
Bob Wilson
Old May 8, 2008 | 12:00 PM
SDcomuter's Avatar
The shark fin antenna will give you worse reception than the factory antenna, which is itsef worse than a good old fashioned 34 inch rod antenna.
Paula
Old May 8, 2008 | 09:11 PM
prius12306's Avatar
Thanks for the bit on the antenna. I don't really use the radio all that much - usually cds - and with the aux input I will use my ipod. I guess it's best to leave it alone in case I want/need the radio, or for future resale.
Old May 9, 2008 | 09:41 PM
prius12306's Avatar
Has anyone installed ipod integration? I saw that the TCH has a kit available to be installed by the dealer. Is there such an option of the Prius? If not, what is recommended? I am looking at the SL2i from VIAS.
Old May 10, 2008 | 07:10 PM
agamotto's Avatar
The only thing that I can highly recommend from experience is getting some Michelin HydroEdge tires once your originals wear out. Much better handling and wet/snow traction.
Old May 11, 2008 | 10:28 AM
prius12306's Avatar
Thanks for that tip. As I drive in snow (upstate NY) that is something I don't mind investing in once I need new tires.
Old Jun 1, 2008 | 12:03 AM
rbashaw's Avatar
I installed the Vias SL2i, hands down a great product! I have one in my 06 Tundra as well. Expensive, but well worth it if you enjoy listening to your own music as much as I do...
Old Jun 1, 2008 | 10:09 AM
wwest's Avatar
35 watt 4300K HID headlights if it doesn't come with them, improved night vision and lower power consumption.
Freeze
Mar 28, 2009 10:11 AM
SanDiegoBlue
Mar 6, 2007 07:06 PM
jamng
Jun 19, 2006 09:24 AM
ender21
Toyota Highlander Hybrid
Sep 25, 2005 10:51 AM
