Question about Emissions
Hi All,
I have a question regarding the emissions from a Prius. I know that the Prius is supposed to be the best hybrid for the environment regarding emissions into the atmosphere. This is my question, is it better because the mpg of the Prius is better and thus there are less emissions since less fuel is being used? Or, are there less emissions per gallon of fuel used?
Thanks!
Thanks!
Originally Posted by javawebgrrl
Hi All,
Thanks!
Thanks!
Check out this link, which has a ton of info on all models.
http://epa.gov/greenvehicles/select.htm
If you have an AT-PZEV rating, you own one of the cleanest vehicles on the planet.
I would say that your Prius emits less pollutants than 99% of all other vehicles as does the HCH. Some emissions are rated at grams/mile, which can all be found at the above link.
Air Pollution Score is rated at grams/mile.
Greenhouse Gas (CO2) is rated at lbs/CO2 per mile.
Hope this helps.
Regards,
Ralph
Originally Posted by xcel
There are many non-hybrid PZEV’s that match or beat its emission profile when measured in g/km or mile The PZEV based non-hybrid Accord and HCH-I (Tier II/Bin2) are two of those that are cleaner due to their more efficient CAT’s while running HS fuel’s.
___Good Luck
___Wayne R. Gerdes
___Good Luck
___Wayne R. Gerdes
Rastin
Mar 3, 2010 04:57 PM
