Pump got stuck
Anyone know why the pump got stuck in the tank at 2 different stations? I had to wiggle and yank it to get it loose; it seemed as if the gas tube in my car was either too narrow or unlubricated in some way. Thanks.
I have never had it stick - entirely, but I note there is a very good ruber-type seal around the hole as well as (I think - eyes are not as good as they never were anyway) a small door or flap.
My supposition is that your particular nozzle may have locked against the seal somehow. I would suggest gentle rotation in the future - and will watch for this to happen myself.
I have experienced at least one pump pressure problem - where the pump almost will not (pump) because of the apparent back-pressure in this system. Most seem to handle it fine, but one self-serve station just refused to give me fuel - I had to really work at it.
Jack
Jack
I have experienced at least one pump pressure problem - where the pump almost will not (pump) because of the apparent back-pressure in this system. Most seem to handle it fine, but one self-serve station just refused to give me fuel...
Is your vehicle fairly new?
Pat
Two stations on the same day??
Jack:
It may be because your vehicle is so new, as was ours. We've not had any problems like that since. I suspect you may not experience the same thing after a few fill-ups.
Pat (in SW Washington State...you're southern neighbor.)
And I haven't worked out how to find out where folks are from yet - is there a way?
Jack
