Prius tire alignment
Old Feb 23, 2008 | 01:16 PM
bwilson4web's Avatar
Engineering first
Wink Prius tire alignment
Hi folks,
After a season of pot-holes and with the spring soon upon us, it is time to plan the spring tune-up and getting the tires ready for vacations. This note covers why wheel alignment is important, an approach and lessons learned.
Wheel Alignment
Wheel alignment toe, the angle in direction of motion, impacts vehicle stability (rolling straight hands off,) drag and tire wear. So high performance race car crews make temperature profiles of their tires after a run to diagnose alignment problems. With an infrared temperature tool, ~$40, anyone measure the tread temperatures just like the race car crews:
In these tests, I drove down the highway at different speeds and inflation pressures for about 5 miles and then pulled off to measure tire tread temperatures. Higher tire pressures reduced the temperature showing reduced wear from lower tire drag. Also, the right side tire had (and still has) an alignment problem, excessive camber. This caused uneven wear and premature replacement of my original tires. But notice that at higher tire pressures, not only were the right-side, tire treads cooler but the wheel camber problem was reduced.
Based upon these tests and having bought a new set of tires, I bought a 'life time alignment' service from Firestone to have it checked anytime I want. Other independent tire shops have similar programs with different terms and conditions. Every Spring and Fall, when I do my twice per year oil change and preventative maintenance, I also check the alignment.
Miss-alignment can occur from hard parking into a curb, a pot-hole or other road stresses. But early detection, before the tire wear is evident, allows us to avoid premature tire replacement and minimize handling issues like trying to wander off the road while changing radio stations.
Adjusting the front wheel toe alignment is easy by tweaking a threaded strut and locking nut and is included in the "life time alignment" service. In contrast, Prius front wheel camber requires loosening and tightening a bolt and in severe cases, the bolt needs to be changed. Yet curiously, neither the tire shops nor my local Toyota service center has shown any interest in equalizing the camber to my specifications since "it is in the green."
Tire alignment systems have a wide range of acceptable Prius toe and camber values. Of the two, toe is more important since this is the angle relative to the direction of travel, the same forces that steer the car. Camber is the vertical angle that helps the outside tire take the turning, centrifugal force but it has less impact on straight-line, tire drag. As my earlier temperature profile shows, keeping the tires well inflated to 50 psi, 345 KPa, reduces the effect of excessive camber and reduce rolling drag:
Image copied from: http://www.procarcare.com/icarumba/r...dia_tires3.asp
Since most of the weight is on the front tires, we rotate them with the rear tires to equalize the overall wear. When tires are rotated each should have an inner and outer tire tread depth measurement. Tire tread depth lets us know how the side-to-side wear is working out, the combination of toe and camber. In the USA tread depth is traditionally given in "1/32" of an inch, ~.8 mm. If the inner and outer depths are off by even one unit, there is a problem that needs to be diagnosed and corrected!
Prius Rear Wheels
Prius rear wheels are bolted, 38 ft-lbs 52 N-m, to a solid axle that ordinarily is not adjustable:
Toyota has a special tool that can change rear wheel toe geometry but usually the dealer just replaces the axle after an accident. Independent shops lacking both the manuals and tool are even less able to deal with rear wheel alignment. Everyone will report a rear wheel alignment problem but typically only adjust the front wheel toe.
Shim Kits
There are after-market, wheel shim kits available that come with sets of metal tabs at "1/64", "1/32", "1/16" and even huge "1/8" shims (if you need a "1/8" shim, there is something dreadfully wrong!) Unfortunately, these kits don't come with Prius rear wheel instructions or even how to use the shims safely.
My rear wheels had both excessive toe and camber but nobody would correct them to my requirements. So I bought the Firestone "life time alignment" service, a shim kit and figured it out:
Since toe impacted rolling drag, I started with the left wheel (the upper pair of graphs) and installed a pair of 1/32 shims on the rear bolts. Shims must always be installed as same sized pairs because with four bolts, if there is any misalignment, the bolts that hold on the wheels can not tighten evenly. This is very, very important since a mismatch can lead to a loose wheel, rocking, and over-stressing the bolts and a wheel falling off!
Unfortunately, I guessed wrong and the toe was worse than ever. But I was able to use the error to calculate that a 1/64 shim on the front bolts should minimize the rear wheel toe and they did a perfect job. Due to the bolt geometry, this also changed the camber angle (lower graphs.) To fix the camber, I used a pair of 1/16 inch shims on the opposite side wheel only to find I over-corrected it. I replaced them with 1/32 inch shims and the camber was as near perfect as I could want and the toe remained perfect.
Now there is a small, shim-sized gap between the wheel and axle plates. This gap can allow salt-water from road ice and snow clearing or coastal areas to invade and attack the metal surfaces. The shims have a zinc coating, which protects them. However, if you live in areas with a lot of road or sea salt, it makes sense to fully remove the wheel from the axle and treat both surfaces with an anti-corrosion compound. Eventually, after two years, I plan to inspect my rear wheel and axle plates for corrosion and compare the rolling drag with and without the shims.
So far, the tire wear has been excellent. The tread depth has been even and the rate of wear per 10k miles indicates I will easily meet the expected tire life.
Questions? Comments?
Bob Wilson
Old Apr 29, 2008 | 02:03 PM
greybeard's Avatar
Default Re: Prius tire alignment
Brian,
Thank you for the information.
You suggest that the tires be inflated to 50 psi, but your test graph stops at 40 psi. Was the additional data dropped off from the graph, or is the 50 psi recommendation extrapolated?
Doug
Old Mar 3, 2009 | 08:14 PM
pskall's Avatar
I was told that the Prius (07) should not have a shim kit installed in the rear tire. (Toyota repair manager). The shop where I had the 30k service done insits that this was necessary. Perhaps it was under warrenty by Toyota????? I am feeling perhaps I was sold on a part that should not have been put in. The repair shop claims the tire was off line and would not wear properly.
Since you know about this what is your opinion? thanks phyllis
Old Mar 4, 2009 | 04:44 AM
Engineering first
Hi,
Let's go over the issues and what we need:
  • Toyota repair manager - if your car is under 3/36000 warranty, I would go with the repair manager, first. Toyota has a rear alignment process that takes a bit of work and a special tool but they can fix a rear wheel alignment. But there has to be 'cause' and that comes in one of two ways:
    • wheel alignment report - this typically includes front and rear wheel numbers for: toe (pointing in or out degrees); camber (top of tire leaning in or out), and; caster (a steering wheel geometry that is all but impossible to change.) Normally you can get a hard copy of the alignment report and posting the numbers or a scanned copy here works.
    • one or more tires with abnormal wear - this is typically found by uneven tread wear depth, say the center treads are great but one edge is worn or an unusual wear pattern in the rubber. A tire shop can give you the proper description.
  • Shop that did 30k work - it sounds like they are not the Toyota shop. We need to understand what they found in either an alignment report or tire wear measurement, individual tread depth, or wear patterns. If they have already put in the shim, their written report is key to understanding what and why. How much did they charge?
If the shim is already in, the only thing that makes sense is to get a wheel alignment report. If all of the numbers are "in the green," you have no problem and the shim is doing what it should do. The other alternative is to drive about 5,000 miles and have the individual tread depth measured when the tires are next rotated. This tire wear pattern is what a shim fixes.
Right now, I'm leaning towards the independent shop because if you had new tires put on this early, it strongly suggests a wear problem that a shim can fix. I use shims to reduce wear and 4-wheel alignment to minimize rolling drag. But I bought a life-time alignment service from Firestone and every time I have my tires rotated, Spring and Fall, I get a full alignment reading. But I do the shims since I trust my own work in this area.
Do try and get the '30k shop' report and share the data. We can then help explain what is going on. I do agree that it would be better if Toyota would handle a rear alignment problem, under warranty. They can even remove the shim BUT find out what they would charge to do it. Negotiate!
GOOD LUCK!
Bob Wilson
jworth
Oct 22, 2009 12:51 PM
BenHCH2
Aug 26, 2006 11:21 AM
crowe85
Jul 23, 2006 06:25 AM
Jason
Jun 23, 2004 12:05 PM
