prius maintenance - brakes and oil changes
Old Mar 14, 2006 | 12:23 PM
lateplate's Avatar
Default prius maintenance - brakes and oil changes
i'm considering a prius, but was wondering if normal wear/tear maintenance is as straightforward on a prius vs. a regular vehicle. my apologies in advance if this has been covered, searched and didn't find a straight answer.
basically, oil changes and brakes are the maintenance items that come to mind. is it any more difficult to perform an oil change on a prius? can i take it to a jiffy lube type place, or do i need to take it to the dealer?
same with brakes...since they have the regenerative component, i assume that changing the pads is not as straightforward as a normal car? or is it?
thanks.
Old Mar 14, 2006 | 01:56 PM
finman's Avatar
Prius geek
Default Re: prius maintenance - brakes and oil changes
Pads are same as any other car, nothing special there. The regen component is tied to the electric motor(s), has nothing to do with pads.
Below 7 MPH the pads engage, above this speed the electric motors are slowing you. Panic stops use both systems (pads and motors).
Basically when you press the brake pedal, you are telling the computer to use whatever means to slow, depending on speed and how fast the pedal is pushed down.
With that being said, brake pads should last a very long time, since they are not being used very often. Amazing technology.
I change my own oil and it's as straightforward as all my other cars have been, nothing special there either.
Hope that helps! Love my Prius.
Old Mar 14, 2006 | 11:14 PM
Tochatihu's Avatar
Agree w/finman on oil. My 2001 Prius only has 85k miles so it is way too early to be thinking about brake maintenance! I can tell you that the rear drum brake shoe self-adjusters look just like those in previous conventional cars. I have heard that the rear brake design is different in the new model, but do not know. I have also heard that brake line bleeding in the new model can only be done with the Toyota hand-held tester (again, seek confirmation elsewhere). This would not necessarily be an issue for front pad changes, but would certainly be for wheel cylinder work, or brake fluid drain/refill.
DAS
Last edited by Tochatihu; Mar 14, 2006 at 11:15 PM. Reason: still lrning how to spll
Old Mar 4, 2013 | 06:17 PM
John Trimble's Avatar
2007 Toyota Prius. What is the procedure to bleed the brake system after a rear wheel cylinder has been changed.?
Feebz13
Aug 7, 2015 07:20 PM
cakley
Chevrolet Volt/Cadillac ELR
Jan 21, 2012 06:54 PM
Freeze
Nov 18, 2006 10:02 PM
bendmac
Mar 1, 2006 11:32 AM
