OEM wheel weight
Old Dec 31, 2005 | 10:25 AM
fastducatirider's Avatar
Default OEM wheel weight
I own a 2005 Prius, and was wondering what the weight of the OEM wheels is (are)
Reason I ask, is that on tirerack.com, they have a 16" aftermarket wheel, that is 12.7 lbs . THat's pretty light..... for a car wheel. but i was wondering if Toyota was already smart enough to put light weight wheels on the Prius from the get go..... i guess i can take the wheel off, de-mount the tire and weigh it... but i'm too lazy... and i can't seem to find the info anywhere...
does anyone know?
those 16" wheels would look pretty cool, and if they weighed less than the stock ones, it might make up for the extra drag created by the slightly wider tires required....
of course 17 or 18 would be even nicer... but the tires get kinda wide at that point... (not to mention heavy)
Old Dec 31, 2005 | 01:17 PM
Clubford00's Avatar
Default Re: OEM wheel weight
Im assuming the Japanees engineers figured stuff like this in their calculations. as well as those ugly little trim rings on the wheels for less wind drag at speed. i took mine off and the wheels look like nice 5 spoke alum. wheels now. Try that first they look pretty nice. Dean
Old Dec 31, 2005 | 05:58 PM
Schwa's Avatar
Here's a picture of my friend's rims without the plastic thing:
Most folks find that their mileage really suffers when they switch to larger wheels on the Prius, not sure if it's strictly a weight issue or if it has more to do with how the car was optimized.
Old Dec 31, 2005 | 06:38 PM
ken1784's Avatar
Originally Posted by fastducatirider
does anyone know?
It is 6.45kg (14.2lbs).
Ken@Japan
Old Dec 31, 2005 | 07:20 PM
xcel's Avatar
Old Dec 31, 2005 | 07:24 PM
Schwa's Avatar
Originally Posted by xcel
Schwa, I am seeing a slight bulge in the sidewall of your friends Prius II RF tire pic. When is the last time you checked his pressures
I think the picture was taken before we pumped them up to 42/40.
Old Jan 2, 2006 | 01:13 PM
MG_HCHII's Avatar
It's not easy being Green
Hi: I autox my Mazdaspeed Protege (getting about 27.5 mpg over 15,000 miles for the year. Pretty good for a normal car.) Wheel weight will affect your car's ability to accelerate at maximum rate, which you never do with a hybrid since it consumes so much gas. Wheel weight also affects handling over bumpy surfaces since your shocks must damp out more energy from heavier wheels. At 14.2 lbs (6.45 kg -- thanks for the info Ken!) this is a relatively light but sturdy wheel for the Prius. I'd keep the wheel and the aerodynamic cover for it if you want to keep your Prius at maximum FE.
However, if you just have to have those pretty new wheels, go ahead and buy them and put them on. They shouldn't hurt your FE more than around 1%, if that.
Hope this helps.
MG
Old Jan 3, 2006 | 11:56 AM
krousdb's Avatar
Hope this helps.
MG
Larger rims usually mean a lower aspect ratio (50 or 60 vs 65), resulting in a larger contact patch which means higher rolling resistance. Also, the sportier tires that come in 16 and 17" sizes usually have a softer compound. That also translates into a higher rolling resistance. While this may not have much effect at high speeds, IMO, you will see a 5 to 10% decrease in FE at lower speeds (below 60 MPH).
Just my humble opinion.
Dan
civicnleo
Dec 21, 2011 09:09 PM
UWAdventurer
Jul 8, 2008 04:50 AM
SamIV
Aug 22, 2007 10:17 PM
TCHandler
Jun 23, 2006 09:07 AM
sirlan
Aug 4, 2004 07:18 PM
