Locking the Prius
Old May 21, 2006 | 09:43 PM
smogless's Avatar
Default Locking the Prius
I like the way you can lock the Prius by pushing the button on the door. However, there have been some occasions where I push the button, and I get a long beep. It doesn't lock the car. Usually, when it does lock it, it gives me a short beep.
Anyone run into this problem? Why will it sometimes lock, and sometimes not lock.. When it does not lock, I have to lock it with my key fob, but that's not as cool.
You know, one big reason for the Prius is the coolness ....
Old May 22, 2006 | 06:54 AM
Douglas's Avatar
Smile Re: Locking the Prius
The long beep usually means you are out of range from the receiver. Step a little closer to the door before you push the button. The range is very limited (about 1-3 feet). It gets worse as the battery in the fob gets weeker.
Old May 22, 2006 | 07:00 AM
foo monkey's Avatar
Default Re: Locking the Prius
Sometimes it takes a time or two.
Make sure you've got your key fob with you, outside the car. One time my wife left her keys in my car and it took me 10 minutes to figure it out and lock the ****ed thing.
Old May 22, 2006 | 07:32 AM
infael's Avatar
Any idea what the fob's battery life is?
Old May 22, 2006 | 11:04 AM
pcflorida's Avatar
If one of the doors is not fully closed, it will do the long beep on locking. Did it to me yesterday when the rear hatch wasn't fully closed.https://www.greenhybrid.com/compare/mileage/car/2647/signature.png
Old May 22, 2006 | 06:58 PM
smogless's Avatar
Thanks for all the responses. I'll have to try this out again. Most of the time, when it does give me the long beep, I'm very close to the door. I know it's not the battery, because I just got my Prius 1.5 weeks ago.
Old May 24, 2006 | 01:20 PM
JeromeP's Avatar
Toyota says about 2 to 3 years in the smart key equipped vehicles. That sounds about right considering the amount of 2-way communication the fob does with the vehicle.
Old Jun 5, 2006 | 07:29 AM
puppetmasta's Avatar
I had the same problem and it was because my wife left her purse in the car with the key fob in it. Thus the Prius detected that the fob was still in the car and wouldn't allow me to lock the doors via the button.
I had to take my fob out of my pocket and lock it with the button. Too bad the system can't be smart enough to detect the one in my pocket and realize that another was left in the car.
econoline
Mar 8, 2007 09:01 AM
skata
Feb 18, 2007 05:15 PM
Loonbeam
Nov 29, 2006 08:41 PM
jasperpearlowner
Oct 2, 2006 11:24 PM
spaziwk
Oct 2, 2006 05:44 AM
