how far can I drive when I drive only on the electical engine of a second gen model?
Hi there,
I'm looking at buying my first Prius (I'm looking at used 2004-2006 models).
I have some questions:
1. Does anybody know how far I should be able to get when I drive only on the electrical engine (so really-really slow)?
2. Maybe a bit more practical: How far should I be able to get on the electrical engine seeing the battery's power go from full to half?
3. Is this a good test of battery status?
4. Any other suggestions to test battery status as a non-mechanic?
Thanks!
-Mike
Thanks!
-Mike
Couple of miles off a fully charged battery assuming you're not stopping. When a lot of slowing down is involved you get some more distance out of the battery since it's charging then you can use that charge to go a little further
I ran into this problem when I ran out of gas (hard lesson learned about the tank capacity becoming 10% less while in very cold weather). I think I only had about half charge or so, only was able to go about a mile but that involved some hills and the cold probably was effecting the battery as well.
No, it's difficult to make this type of test without a system that actually reads the battery consumption rate have any real meaning between a good and not-so-good battery.
They have systems like CANview and such but they are expensive and takes time. I can't think of anything specific besides putting it under a load while taking out voltage and amp readings.
Curated Content Editor
Tesla
Nov 4, 2013 11:00 AM
