Fitting 20" wheels
I want 20" wheels to impress thee ladies. What do I have to do to fit them? Or will they fit like it is? Help me with my game.
Re: Fitting 20" wheels
There are risks so what I'd suggest is get just a single, 20" wheel and tire (cheap) and check the fit in the front and the back. Don't drive around with it, just check to see if it will fit and there is enough clearance to allow you to pass over bumps. If it checks out on the lift, then go ahead but 'all bets are off' on any Toyota support for problems. Use the 'cheapie' as your full-size spare and check that it fits in the trunk tire well.
BTW, greater ground clearance will also lead to more air passing under the car and under-body drag. It will also 'raise the seat' by half of the increased diameter. For my wife, the seat height was important but your ladies may have 'a different suspension.' <grins> GOOD LUCK! Bob Wilson |
Thanx Bob. I'll slap on a bodykit to reduce some of the ground clearance gained. Has anyone ever seen 20's on a Prius?
Capt, have you looked into low resistance tires first? Those 20"ers might sacrifice some gas mileage!
I'm not worried about gas mileage, just tha ladies, my buddies get all the females with their pimped rides. I get a discount on gas from working at Wal-Mart anyways.
You're kidding, right?
All my friends have 20's or bigger rims on their rides, I gotta have 'em too. Are you saying it's not possible?
Originally Posted by CaptainPicard
(Post 106966)
Some of these you can buy but some would have to be made. That would make your car unique, a one of a kind. Then get the EV mode switch and you can go EV anytime you want and 'sneak up' on your homies. <grins> Best of all, these changes not only make a statement but they also make your ride more comfortable and efficient. Bob Wilson |
Thanx Bob, but hubcaps and wheelwell covers will make me look like a dork. Now the body kit and neons are what I'm talkin about! So I guess 17" chrome wheels are the safest bet for me.
That's sounding much more sensible! Are you seeing any other interesting modifications out there? I think one of the body kits (& a nice paint job) will make the most dramatic statement!
