Check Engine Light code P1118
Has anyone received Check Engine Light code P1118? We have had this one come on and off for the last month or so. The code on our reader indicates "Manufacturer Control Fuel Air Metering".
Thanks for your consideration.
-Ed
-Ed
That's a high temperature alarm (coolant) in a Prius. Either air in the coolant system (A Prius has two separate coolant circuits: one for the engine and one for the power electronics) or a faulty water pump (My Prius has four water pumps: Engine, Electronics, Heater coil, and Thermos).
In other cars it is a fuel/air metering problem. Your Honda could be different.
JeffD
JeffD
Jeff,
Yes, this code is from our 2007 Prius. Any suggestions on how we should narrow this down?
-Ed
-Ed
JeffD
JeffD
It seems to point to the heat recovery sensor (the Thermos bottle). Good luck in tracking it down. The Prius_Technical_Discussion group (Yahoo) or PriusChat in the GenII Maintenance discussion area would be good resources for help.
JeffD
JeffD
You don't happen to know how we can find the correct part number, do you?
http://www.selidori.com/tech/prius/DOC/ An Italian site.
- 2004-2005 Prius are covered by Tech2004.rar
- 2006-2009 Prius are covered by Tech2006,rar
- 2010 Prius (Tech2010.rar) seemed to be the user manual
the last time I looked at it.
JeffD
cak615
Oct 28, 2013 08:11 PM
SadCarTime
Jul 9, 2012 08:05 AM
