can interior car lights drain battery?
My battery recently died when I left my '05 Prius parked for a few days, and had to get it jumped. The hybrid battery was still about half full, so it must be the auxiliary one. I can only come up with one candidate problem, so I'd love to know if I'm on track or not.
When the car is turned off and car is locked then the headlights turn off, and the inside light triggered to door opening & closing turns off. However, the reading light (the lights above the rear-view-mirrow to the left & right of the light triggered by door opening) apparently does not. At least, when I walked around for 5 minutes and came back it was still on.
Now, in my case, after the car was jumped I found that my wife had left the reading light on when she parked the car 3 days ago. Could it be that this is the only light in the car that does not automatically turn off, and hence that tiny light can actually drain the battery if left on for several days? Is this a "feature" or a bug? I'm guessing it's a feature to let me say read in the car when it's turned off, but it ended up being might inconvenient in this case.
Anyways, just want to make sure I diagnosed the problem correctly so that I don't have to wonder if the car will be kaput again tomorrow morning for instance. Thanks in advance.
Unless a hybrid's different in some way, then yes, interior lights left on for long periods can drain the under-hood 12v (traditional) car battery. I've never fully drained a battery due to this but it happens once in awhile in my '92 Corolla since there are no warnings or notices about lights (including headlights) left on.
Originally Posted by GeekGal
...drain the under-hood 12v (traditional) car battery...
Luckily it doesn't take much to jump a Prius as the actual starting of the engine happens with the HV battery, so the 12v battery just needs enough juice to fire up the HV relays and computers, then the built-in charging system takes care of the 12v.
A Prius does use a rather small size of 12v battery since it doesn't need high starting current, so they can drain a bit quicker than most cars, but should still be able to supply power to accessories for quite a while without a problem.
Originally Posted by Schwa
It's actually not under the hood, but yes this can happen...
Kuroyama, your diagnosis is almost certainly correct. The Prius high-voltage battery cannot be discharged in this way. My only concern is that typically, once lead acid batteries are fully discharged, they have lost some capacity. If the problem does recur you should consider replacing that battery. It is sometimes possible to convince a Toyota shop to replace a 12 v battery under warranty, if your diplomatic skills are good.
DAS
DAS
DAS
DAS
We just had to jump our prius this morning. I looked and my 3 year old son had turned the interior light to on. We were gone for a day and a half so it must have run the battery down. It started fine once we jumped it.
Crystal
Crystal
LakeSilverado
Jul 30, 2011 07:29 PM
sanosteam
Jan 4, 2010 02:41 PM
dcemureviews
Jun 22, 2009 08:28 AM
