Highlander Armrest
Old Aug 29, 2006 | 09:46 AM
JMSinMD's Avatar
Thumbs up Highlander Armrest
I have to admit I drive a non-Hybrid Highlander but I found a company willing to help all of us out. I know I'm not the only HL driver that hates the factory armrests so now there is a solution. http://www.toyotanation.com/forum/t153292.html . I couldn't be happier with mine. Jon.
Old Aug 29, 2006 | 09:11 PM
drmperalta's Avatar
Default Re: Highlander Armrest
How were you able to remove the original armrest?
Old Aug 30, 2006 | 04:40 AM
JMSinMD's Avatar
It was simple, remove cap that covers bolt, using a wrench with extension remove factory armrest. As I stated, the hardest part was finding the tools in my own house. Jon.
Old Aug 30, 2006 | 08:46 AM
luvmy356's Avatar
Does the new armrest stop at different angles vs all the way up or all the way down? I find the stock armrest position a bit low.
I miss the design that was on our other Toyota, the armrest could be placed in different positions.
Old Aug 30, 2006 | 01:26 PM
JMSinMD's Avatar
Re: Range of motion
The aftermarket armrest keeps the same range of motion as the OEM armrest. It's significantly wider and much more comfortable though. Jon.
Old Aug 30, 2006 | 09:22 PM
drmperalta's Avatar
Funny you mentioned that the stock armrest height is low since I find it too high.
In your case, it is easy to fix. I read somewhere in the Sequoea forum about putting something below the armrest to jack it up, like a solid plastic tissue box for example.
In my case, since I want it to lower, I had to dismantle it, sort out the bolts and washers inside and did some modifications. I had to remove a plastic washer, and reposition to lower the armrest. This resulted to a pin that is out and beyond the corresponding groove and rubbing against a metal plate. I had to jam two layers of additional washers on the opposite side to balance the force of the pin. I then tightened the bolt with the armrest at the desired height. It is now at a very comfortable height, just like in my sienna.
This resulted to a fixed armrest and does not fold up anymore. I don't mind that it doesn't go up since the arm rest in my sienna is always fixed in one position and is rarely folded up.
Hope that helps.
Old Aug 31, 2006 | 07:48 AM
drmperalta's Avatar
just got back and bought two washers that are large enough to accomodate the retaining bolt of the armrest. This time the washers are at the appropriate location and the original plastic washer is removed. The washers created enough clearance so that the pin does not touch the stopper. I can now angle the arm rest to ANY position and then tighten the bolt with 14mm socket wrench.
Of course, the arm rest is fixed unless you loosen the bolt. My socket wrench is in my car right now just in case I need to fine tune the angle.
Mark
Old Sep 8, 2006 | 02:00 PM
FL07THC's Avatar
Oh this is GREAT! Im getting one!
Old Sep 13, 2006 | 06:52 PM
JMSinMD's Avatar
Has anyone else ordered one? My wife was skeptical at first, since it's her daily driver but now she understands/feels how much of an improvement this had made. Toyota should be knocked in the head for not designing these armrests properly in the first place. Let's hear some reviews from people who have bought it.
JSuppi
Toyota Highlander Hybrid
Nov 8, 2020 12:51 PM
nsxman2001
Oct 19, 2014 06:26 AM
greenguy2010
Dec 6, 2012 10:17 AM
bwilson4web
Feb 12, 2007 04:19 AM
Ricco
Honda Insight
10
Oct 5, 2005 10:30 AM
