Engine Air Filter
Old May 7, 2007 | 10:14 AM
me2's Avatar
me2
Default Engine Air Filter
Does any OEM company make engine air filters for 06 HiHy? Fram didn't have one in their parts catalog (at least at Wal-Mart). I tried an air filter for regular Highlanders, but it's a little too tall. Will I be forced to go to the Toyota dealer and get a filter, and if so, how much do they charge?
Old May 7, 2007 | 11:57 AM
nomorebenz's Avatar
Default Re: Engine Air Filter
I don't know if anyone but Denso (Toyota OEM) makes them. It should cost around $23 for the part.
Old May 7, 2007 | 01:48 PM
andybl's Avatar
K&n makes one -- $49
Old May 29, 2007 | 04:25 PM
HB-RX400h's Avatar
Lightbulb Re: Engine Air Filter
Originally Posted by andybl
K&N makes one -- $49
Does anyone have any data that shows that the K&N filter helps get any better mileage in the RX400h or Highlander? In my last two cars I had K&N filters and the claim was increased HP. But I also changed out the air filter housings for increased air low.
I would change out the filter (in the stock housing) if it helps, here is the http://www.knfilters.com/search/prod...x?Prod=33-2344
Old May 29, 2007 | 10:20 PM
nomorebenz's Avatar
No data but I'm sure it's marginal at best. If you think about it, the engine would have to "want" the increased air to mix with the increased fuel flow under hard acceleration.
I say get it if you want it. The K&N's don't dirty the engine oil enough to necessitate more frequent change intervals than the already accelerated intervals for cars in America.
Old May 30, 2007 | 08:15 AM
petesell's Avatar
agreed. clean paper filter will flow whatever the engine requests. should be a negligible to non-existant hp or fe gain. the k&n is nice since it will flow for a long time & won't get clogged as fast as the paper. also, it's a lifetime filter with a cleaning/re-oil every 50K or so. just be careful not to overoil as that could destroy the maf sensor element - a problem that plagues the vw/bosch maf's (my other car is a vw). i would suspect our maf is of better quality.
dgyimao
Dec 31, 2009 09:38 AM
sanosteam
Dec 26, 2009 07:17 AM
bugs
May 26, 2009 12:05 AM
fired_up
Aug 26, 2007 09:04 PM
