whump, whump, whump, whump, etc.
Old Jul 24, 2008 | 07:44 PM
vioarc's Avatar
it's just a car...
Default whump, whump, whump, whump, etc.
My TCH is virtually silent, even after 30,000+ miles except for an annoying low beat coming from one of my bridgestones which seems to be getting louder as time goes on. Anyone else have similar experience?
Old Jul 24, 2008 | 08:07 PM
RadioTek's Avatar
Default Re: whump, whump, whump, whump, etc.
Last time I had one of those sounds, it was a tread separation in the tire. You might want to check it out, or have it done if you don't feel confident. Not to cause any panic, but if it is one, that's a safety issue.
Old Jul 25, 2008 | 04:46 AM
RedLdr1's Avatar
+1 on RadioTek's answer. The last time I had that sound it was a tread seperation in a Firestone tire...
Note: If you have used a Instant Flat Fix or other tire sealant / balancer product they can cause a similar sound. It would be most noticeable when the tire is cold and usually goes away as the tire warms up...
Old Jul 25, 2008 | 06:07 PM
schmidtj's Avatar
Keeping Toyota Solvent
Yep on the tread separation speculation. I had 2 tires fail that way but that was MANY years ago. I haven't known anyone who has had a radial tread separate.
Get it checked especially if you do any highway driving.
Old Jul 25, 2008 | 07:12 PM
abward's Avatar
Out of curiosity, when did you purchase your TCH? I assume it is a 2007. Is there a serial number on these tires?
Old Jul 27, 2008 | 08:38 AM
vioarc's Avatar
it's just a car...
Thanks for the replies.
No visible separation.
No "fix a flat" or other repairs that I'm aware of.
The Bridgestone Turanza has a "DY218E" and "0606" mark.
The TCH is a 2007 delivered May 2006.
Old Jul 27, 2008 | 12:19 PM
theox's Avatar
HY POD
"0606" means that the tire was fabricated the 6th week of 2006. Therefore, I don't believe it's an "old tire" issue.
Old Jul 27, 2008 | 12:59 PM
vioarc's Avatar
it's just a car...
It's difficult to spell out a sound in text.
It starts out as described above at slow speed and speeds up as rotation increases to become more of a continuous oscillating noise.
Old Jul 27, 2008 | 01:49 PM
rburt07's Avatar
On your next tire balance and rotation, I would ask for a close visual inspection to look for this problem. You may want to also look at your tread depth. Some shops include it on your receipt to help sell new tires.
You may have a visual wear spot caused from where the tread may have separated.
Old Aug 12, 2008 | 07:28 PM
vioarc's Avatar
it's just a car...
When I took it to the local Toyota dealer, the guy at the counter only looked at the driver's front and declared that I needed new tires. I explained that I'd like to know what caused the noise. He said it didn't matter and that they would not consider a rotating the tires.
I went across the road to a tire dealer. They mounted four (4) Michelins and told me my TCH really needed alignment.
I suppose I should have "reminded" the dealer to check alignment EVERY time I took it in for the usual 2,000 mi. rotation.
