Toyota Platinum Extended Warranty - What's Covered
Old 08-03-2006, 01:30 PM
bmgoodman's Avatar
Default Toyota Platinum Extended Warranty - What's Covered
OK, so the following isn't covered under the Platinum warranty:
List of Excluded Components <li>
Accessory Drive Belts <li>
Batteries <li>
Body Panels <li>
Brake Linings, Pads and Shoes <li>
Bumpers <li>
Carpet <li>
Chrome <li>
Clutch Friction Disk and Pressure Plate <li>
Dash Cover and Pad <li>
Door Trim, Handles and Fabric <li>
Filters <li>
Fluids <li>
Glass (including Windshield) <li>
Headliner <li>
Heating Hoses, Lines and Tubes <li>
Hinges <li>
Hybrid System Main Relays <li>
Hybrid Vehicle Battery <li>
Hybrid Vehicle Battery Module/Pack <li>
Hoses <li>
Interior and Exterior Trim Moldings, including but not limited to, Cup Holders, Ashtrays, Covers, and Vents <li>
Lamps <li>
Light Bulbs <li>
Nuts, Bolts, Clips, Retainers and Fasteners <li>
Paint <li>
Rotors and Drums <li>
Rust and Corrosion Damage <li>
Seat Covers <li>
Service Plug <li>
Shiny Metals <li>
Spark Plugs <li>
Structural Framework and Wells <li>
Tires <li>
Vacuum Hoses, Lines and Tubes <li>
Weather Stripping <li>
Wheels and Rims <li>
Windshield Wiper Blades (Rubber Component)
It seems like a long list. I am wondering what people's thought processes were in evaluating whether to buy the extended warranty. When I thought of "Platinum" as being almost an extended "bumper-to-bumper" warranty, I was 100% for doing this. Now I see the long list and wonder once you remove Hybrid components that are already covered by a longer warranty, and you exlude everything on this list, is this still a decent "investment"?
Does anyone know if you must get any repairs "pre-authorized" with some plan administrator? Any "catches" anyone can think of? I don't like to drop $600+ dollars on this just to get surprised later.
Thanks!
Old 08-03-2006, 01:46 PM
Orcrone's Avatar
Default Re: Toyota Platinum Extended Warranty - What's Covered
I don't have a good answer for you. I'm just very wary. I expect to have an engine seize up, go in for the warranty repair and be told that it was caused by a loose nut that wasn't under warranty.
Old 08-03-2006, 04:14 PM
Litefoot's Avatar
In a way you are correct. I just called Claims at Toyota EW and he said that if that happened you would not be covered. How ever he has not ever seen that happen. I was amazed to see hinges not covered, The rep said they are a heavy wear item. O well !!!
there alot of other things that are covered. a/c ,ps, pb ,electical , and th list goes on.......
This being the first year for the TCH , there may be some bugs that might not show up in 36 m. So $645 for a extra 4 yrs ($161) per year is reasonable. Just my opinion.
Cheers.
haroldo
09-08-2010 01:26 AM
McGyver
09-28-2009 09:01 AM
macdracer
03-18-2009 07:39 PM
ctdeng0
01-03-2008 11:39 AM
keithet
08-02-2006 03:17 PM
