Tire pressure indicator
Today I noticed tire pressure on my 2009 Hybrid Camry appeared low I usually run tires at 38 psi and they were at 32 psi. I inflated all four tires to 38 psi and opened the glove box to reset tire pressure indicator and discovered that the reset button had been removed. The car has only been serviced by the dealer where I purchased it from. Could this have been done by the dealer on a recall when I had it serviced?. The car has 49,000 miles with no other problems.
It has probably been pushed into the dash. As an aside, why did you try to reset? If you had it set to 38 psi, you shouldn't need to reset it again. Remove the glove box (like you do when changing the cabin filter and take a look to see if the button has been pushed thru the side and not re-installed.
There is no TSB that I am aware of that would let the dealer remove the reset button.
