TCH navigation system
2 quick questions,
Does the TCH navigation system show altitude (elevation above sea level) as well as location?
Is it possible to change the measurement units back and forth between metric and US?
You can see the altitude if you go to the GPS info screen on the override backdoor. Instructions for getting into the override backdoor are all over the place.
There is a units setting in the setup screen, but I have not used it to see its effect. However, I do know that if you switch your language to french or spanish, you get everything in metric.
[QUOTE=gaijin42]You can see the altitude if you go to the GPS info screen on the override backdoor. Instructions for getting into the override backdoor are all over the place......
/QUOTE]
I see the GPS info button, but when I press that, I don't see anything that looks like altitude...please advise... thx
/QUOTE]
inetport
Apr 16, 2009 08:54 AM
tigerhonaker
Jan 18, 2006 04:05 PM
