static when iPod is plugged into power outlet
Old Nov 6, 2006 | 02:18 PM
wallpad's Avatar
Default static when iPod is plugged into power outlet
I tried my iPod in the TCH this weekend. There was annoying static coming from the speakers along with whatever song was playing on the iPod. I determined that if I unplugged the power cord from the bottom of the iPod, the static went away, and the music sounded good.
Has anyone else expereienced this?
Any thoughts on the problem?
Old Nov 6, 2006 | 03:11 PM
jdenenberg's Avatar
Engineering Professor
Default Re: static when iPod is plugged into power outlet
This problem has been discussed before. The solution lies in either a static filter or a 'ground isolator' (eliminates 'ground loops'). I don't recall which solved this particular problem in the earlier discussions.
JeffD
Old Nov 6, 2006 | 06:08 PM
spiff72's Avatar
Ground loop isolator. I got mine from crutchfield. Worked like a charm.
http://www.crutchfield.com/S-cFImmYm...+loop+isolator
Old Nov 6, 2006 | 08:23 PM
jbollt's Avatar
I have my iPod connected via a Belkin "Auto Kit for iPod" (BestBuy for around $30). This eliminates any "noise".
It plugs into the 12v outlet. It has it's own aux input. I plugged one end of the "mini to mini" gold plated cable I bought (at Walmart for about $4) into the aux input on the car, and the other end into the aux input on the Belkin.
The Belkin then has a cable that plugs into the bottom of the iPod, (dock connector) and allows the iPod to charge and play thru the aux on the car. This also allows the iPod to reach into the center of the car... with only one wire attached directly to the iPod...if a passenger wants to change songs.
It will pause the iPod when the car is shut off, and all that is needed is to push play when I start up the car again.
nice!
here's a link to the Belkin site
http://catalog.belkin.com/IWCatProd...oduct_ID=149006
Old Nov 6, 2006 | 09:00 PM
jbollt's Avatar
Sorry for off topic post.
I just noticed that the last 3 posts are all from "Jeffs" ...I guess we Jeffs know a great car when we see one!
Old Nov 7, 2006 | 05:40 AM
spiff72's Avatar
Heheh. Darn right!
Old Nov 7, 2006 | 08:58 AM
wallpad's Avatar
OK just a follow up question - sorry if this sounds contrary...
The ground loop isolator is isnerted in the aux input path. But I determined that it was the power cable causing the noise, not the aux. Does it still make sense that the ground loop isolator will fix the problem?
Thanks,
Paul
Old Nov 7, 2006 | 09:03 AM
CGameProgrammer's Avatar
The TCH instruction manual actually mentions this problem, and it says to unplug power from the iPod when playing. Personally it's not a big deal leaving it unplugged for a week at a time, or more, then plugging it in for a few hours to (fully) recharge it. I just have a Nano though; maybe the regular one's more power-hungry.
Old Nov 7, 2006 | 09:09 AM
wallpad's Avatar
CGameProgrammer, that's probably the best solution, especially since it's free...
Old Nov 7, 2006 | 09:24 AM
jdenenberg's Avatar
Thanks,
Paul
Paul,
If the problem is a ground loop (as has been noted), this will fix it. Note that if you unplug the audio cable, the noise also goes away (also the musical noise). Unplugging either cable breaks any exisiting ground loop.
The same vendor has 12v power filters which is the other fix if the isolator fails to silence the noise.
The Belkin unit mentioned appears to go after both possible noise causes. I don't have an aux. audio input in my Prius so I can't definitively say which way to go, but each of these devices are reasonably priced. Good luck.
JeffD (Electrical Engineering Professor)
