Remove speed limitor in TCH?
Old 04-23-2009, 10:16 PM
gvrv's Avatar
Default Remove speed limitor in TCH?
Hello
This is my first post in this forum!
I have recently bought a Canadian 2008 TCH and exported it to Europe!
I have just received my toyota camry.
Since I live near Germay I use a lot the german autobahns where in some places there is no speed limit......
Is the car limited to 120 mph?? the car goes very fast to that speed, but not over it!
Is there any way to remove the speed limiter?
Old 04-24-2009, 01:38 AM
rburt07's Avatar
Default Re: Remove speed limitor in TCH?
You might try contacting Toyota in Germany and ask if the TCH speed governor can be moved up. This may be done on the cars ECU.
Be sure you check your tires speed rating, to see if they are designed for the faster speeds.
Old 04-24-2009, 07:01 AM
jdenenberg's Avatar
Engineering Professor
The speed limiter is real (104 MPH limit in the Prius) and protects the HSD parts from exceeding their maximum RPM. One way to go faster is to put on larger tires so that your car thinks that it is going slower.
JeffD
Old 04-24-2009, 09:02 AM
mikieboyblue's Avatar
Sweet... 120 mph legally! Woot! I wonder what MPG is like at that speed.
Old 04-24-2009, 07:45 PM
HyCAMBill's Avatar
Did you try putting it in the B mode? I would start out at a slower speed with the B mode. Some features don't work in the B Mode like the cruise control.
Old 04-24-2009, 07:48 PM
JoeRemix's Avatar
I'd imagine not that great, and talk about over-working a 4-cylinder engine! Honestly, if you're planning to travel at high speeds, you'd probably be better off in a German car (BMW or Audi) rather than a hybrid. Top Gear ran a test at high speeds, and I believe it was an M3, but the sports car outpaced (FE-wise) the hybrid (I believe a Prius) at high speeds, probably due to the fact the M3 was designed for high-speed performance, and the hybrid was not.
Old 04-24-2009, 07:50 PM
JoeRemix's Avatar
Obviously, an M3 is much more expensive than the TCH. But something similar like a 128i or 135i is in the same price range. I've heard rave reviews of the 135i, I wouldn't mind taking it out for a spin on the autobahn! Not that I don't love my TCH, but for high speeds, I think I'd rather have a sportier car designed for it! TCH for FE, BMW for speed/performance/sporty handling.
Old 04-24-2009, 07:51 PM
HyCAMBill's Avatar
I agree. I am not sure the engineers that designed the TCH had plans for it to be on the Autobahns. I am sure Haroldo will have something to say about that!
Old 04-24-2009, 08:55 PM
BOFH's Avatar
I like Top Gear, a fun show BUT this bit on the Prius vs. the M3 was a farce. The premise was to run the Prius as hard as they could and have the M3 follow on a race track and see which car used less fuel. Since the Prius was run at full throttle the little 1.5l was run very hard. The M3 on the other hand hardly had to try to keep up so it used less fuel.
Overall, I don't think the Camry is built (handling and brakes) to handle those kinds of speeds. It's one thing to get a car to go in a straight line at high speed it's a completely different thing to keep it under control when something unexpected happens.
Old 04-26-2009, 10:56 AM
Frodo's Avatar
Originally Posted by gvrv
Hello
As others have stated, you are likely to have a bunch of problems (specifically MG1 overspeed) if you tried to exceed the factory governor. The TCH is a good car, but sustained high-speed operation is not in its high-priority design objectives. At that speed, fuel consumption, wear, brake capacity and handling safety are all likely to be at or beyond their limits of safety. For durability sake, I would not consider operating the TCH at any sustained speed over 100 MPH. Get used to staying in the right lane drafting the big rigs and enjoy FE double or triple (or more) the left lane rockets.
Quick Reply: Remove speed limitor in TCH?
