Remote Starter - Dealer installed
Re: Remote Starter - Dealer installed
No, the Smart Key system will not start the car. I don't have remote start, so I can't help you there, but I do know that the "out of the box" key fob will not start the vehicle.
I know that TCHs have come through with remote starters pre-installed (be it in Japan or port-installed) but I'm curious if anyone has had their dealer do it and what they charged.
I like the fact that the existing key fob controls it.
But in a Smart key system there is no option to put a key in, so the answer is , " you can only get a OEM toyota hybird remote start installed" by the dealer , i mean you can buy it dealer can install it.
because if you buy a regular remote starter, it will start the car, but it wont shut it off as it would in a regular car if you dotn put the key in, since there is no key.
I dont know how true this is, but thats what i was told, and rather to take chances i jsut bought the toyota OEM remote start and had it installed for $48.
You can buy on at donjacobstoyota.com
Originally Posted by fredo48
Had mine dealer installed - ran about 450.00. Works fine. Fred
Originally Posted by Rcommander
Hey then i wanna get one too, how does it work, you start it and then when u get in the car you press the power switch? and are you using 2 remotes (Camry and RS) or just one, for locking/unlocking and starting? does it affect the smartkey system?
http://www.toyotaiguide.com/iGuide_CamryHybrid.htm
See the category "Keys and Doors" - "Remote Engine Starter". Operation with the SmartKey is the same as the example shown.
The Remote Starter apparently is available as either a port installed or dealer installed option.
Note: When you unlock the car to get in, the engine will shut off and you'll need to restart it after getting into the car.
