Radio/bluetooth weirdness
Old Apr 10, 2008 | 06:27 AM
mikec442's Avatar
Default Radio/bluetooth weirdness
Hi all,
I've been having intermittent problems with my 2007 TCH and the audio system, wondering if I'm alone. I have the NAV system on my car (if that helps)
Both have happened only 1 time over the past couple months:
  • Talking on the phone, all of a sudden, the call drops from the handsfree with a "Bluetooth Device disconnected" message on the screen. I grab my handset, and notice the call is still connected, finish conversation... After the call, the car would not recognize the phone again until I shut off the car and restart it. ("connect" and "auto connect" didn't work)
  • Listening to AM radio, received a call, talked, and disconnected at the end. Radio didn't return to a listenable state after the call. Turned up the volume to 50, nothing from the speakers. Noticed "Aux" worked, and CD. FM2 worked for about 5 seconds, made a weird sound, then muted. AM/FM1 didn't work at all. Stopped car and restarted, and all was well again...
Has anyone else experienced this, or does anyone have any suggestions?
Old Apr 10, 2008 | 07:25 AM
haroldo's Avatar
Default Re: Radio/bluetooth weirdness
I've noticed that there are times that AM (all stations) would be silent. Toggling through FM1/FM2/AUX and back to AM returns it to an audible state.
Not sure if it's only AM that goes silent, since I listen to AM most of the time and don't recall getting calls while listening to FM.
Unlike your situation, the FM stations played properly...although I don't remember if it was on for 5 seconds or not, I was quickly toggling to get back to AM.
Old Apr 11, 2008 | 03:48 AM
haroldo's Avatar
...update
I turned the car on this morning, it was set to FM1.
I didn't use the phone, although it was in BT range and recognized so the BT icon was on the screen.
I listened to FM for five seconds, toggled to FM2/AUX and when I got to AM it was silent.
I toggled through again and it was playing normal.
So, the problem isn't necessarily related to using the BT phone, since I hadn't.
Not a huge problem, since cycling through clears the problem.
Old Apr 11, 2008 | 04:45 AM
CJO2007CamryHyb's Avatar
Sounds like possibly a software error, especially since it comes back on after you turn the power off and then on again. It might also be an intermittnet thing with the cars audio system. It will probaly take some effort to determine wihch is the case. try and eliminate as many things as possible by troubleshooting. Hope this helps.
Old Apr 11, 2008 | 07:09 AM
haroldo's Avatar
Well, I eliminated the phone being used as a culprit, since mine wasn't.
This error, unfortunately, can't be forced or recreated, it just has to be noticed.
For the record, I have a non-NAV 2008. I booted the car into FM1 and the car discovered the BT device. Not sure what other variables are worth mentioning.
Old Apr 12, 2008 | 01:49 AM
haroldo's Avatar
Happened again, incoming call while on FM1.
I tried to recreate by dialing a call from FM1, to no avail. Maybe it happens on incoming calls while on FM1?
Only AM is silent when this occurs.
Old Dec 3, 2008 | 07:39 PM
Electrick's Avatar
I just started having Bluetooth dropouts just like described by mikec442 on my 2007 TCH after flawless operation for 20K miles. Friday I lost an incoming call and today I lost an outgoing call. It's the same phone I've had for the life of the car and the disconnects have only occurred in the middle of conversations. BT reconnected after turning car off then back on again. Did you ever fix the problem? Is anyone else seeing this?
Old Dec 4, 2008 | 04:14 AM
haroldo's Avatar
Bluetooth issues can be a problem with the handset. I have a Palm Treo and until an update, the handset would frequently lose bluetooth connectivity. I've also noticed that the pairing, while now >99% reliable, will occasssionally drop a connection. Rebooting (oops...restarting) the car typically will repair the issue. Not a great fix (but it is a workaround), but to me, it's not a problem worth aggravating over, either.
Old Dec 5, 2008 | 06:06 AM
mikec442's Avatar
Rebooting the car seems to be the only answer. If it makes you feel better, mine's only done it one time since I posted.
I don't think its a fault of the phone (looks like everyone who's experiences it has a different phone - I have a LG VX8300 FYI), but a software glitch.
spiff72
Apr 4, 2008 12:53 AM
bmcmullin
Apr 3, 2007 05:01 PM
bwilson4web
Oct 7, 2006 08:27 AM
mickster
Jun 5, 2006 06:13 PM
copyboy1
Oct 18, 2005 09:49 AM
