put deposit on blue ribbon hybrid tonight
Old 04-12-2007, 06:26 PM
camrydan's Avatar
Default put deposit on blue ribbon hybrid tonight
hi
after reading ALL posts on various sites, i put a deposit on a blue ribbon hybid, no leather, moonroof, etc, just the way i wanted it
no word when i will be getting car, they will check around and let me know
im so excited!
thanks
dan
mississauga, ontario, canada
Old 04-12-2007, 06:33 PM
mikieboyblue's Avatar
Default Re: put deposit on blue ribbon hybrid tonight
Congrats Dan!
Old 04-12-2007, 07:35 PM
wilsons66604's Avatar
Led-footed HyBrid geek
WELCOME to the club!
You'll love it
Old 04-12-2007, 08:15 PM
tjd24's Avatar
From one Blue Ribbon Owner to a new Blue Ribbon Owner - Best of Luck !!!
Old 04-12-2007, 09:22 PM
07CamHybrid's Avatar
Camry Freak
he he he... maybe we should have a special Blue Ribbon Hybrid Club...
Congrads... you'll love it once it arrives.
It really is an awesome color... I was convinced that my next car would be the dark gray color... until I saw the blue ribbon in person... I changed my mind instantly.
Old 04-14-2007, 05:19 PM
tjd24's Avatar
FYI for the "Band of Blue Ribbon" Owners - attached are pics of the color keyed mud guards in Blue Ribbon Metallic purchased from TRD Parts 4 U.com (Toyota of Dallas) http://www.trdparts4u.com/MC-CDCE-DA.aspx - note great experience with this vendor - I'd recommend. Also, you need to buy Front & Rear separately.
As my local NJ dealer had already drilled the holes to put on the unpainted Black mud guards (which I had him remove) I was able to install myself easily. If not drilled the Rear Tire would need to be removed or an angled drill set would be needed.
File Type: pdf
Old 04-14-2007, 06:14 PM
camrydan's Avatar
hi
very nice, is drilling involed?, im thinking of a se grille in the future, but first get the car!!, i guss they will let me know on monday when its coming in
bye
dan
Old 04-14-2007, 09:29 PM
tnsig's Avatar
Congrats Dan. I also have the BRM TCH. I love the color.
Old 04-15-2007, 04:53 PM
Camry Freak
I have also bought the color keyed mud guards from this vendor.... I also can highly recommend them.
Old 04-16-2007, 08:54 AM
tjd24's Avatar
Dan - the Mud Guards require drilling in front and rear (the rear requires taking the tire off or using an angled drill bit if you have one). A mix-up with my dealer enabled me to get the holes drilled (I thought the dealer ordered the color-keyed, which he didn't & put on the standard black which I thought looked terrible so he took them off & didn't charge me for labor).
I'd ask the dealer to drill the holes gratis (for customer satisfaction as well as avoid ~$65/hour labor rate) then put them on yourself.
The rear is a bit tricky even with the hole drilled as you need either a really short screwdriver or a long necked screwdriver to get torque at an angle.
Definately worth the trouble. Good Luck with your new TCH.
