Procedure to clear NAV and Phone Settings
Old Feb 12, 2013 | 10:16 AM
schmidtj's Avatar
Keeping Toyota Solvent
Default Procedure to clear NAV and Phone Settings
Does any one have a procedure to clear the NAV, Phone and Phonebook in anticipation of selling the 2007 Camry Hybrid w/NAV?
I will also erase the Homelink but are there any other settings that should be cleared for best practices?
Thanks,
J
Old Feb 12, 2013 | 06:23 PM
SteveHansen's Avatar
Pragmatist
Default Re: Procedure to clear NAV and Phone Settings
Disconnect the wire from the + terminal of the 12 volt battery in the trunk. Leave it disconnected for a minute or two before reconnecting.
Be careful not to let the wrench touch any other metal parts while it is touching the + terminal. There is plenty of space, so it is not difficult.
Old Feb 12, 2013 | 06:57 PM
ukrkoz's Avatar
Then be prepared to all kinds of lights to come up, after you try to start her, after you had battery disconnected. Right, Steve?
Old Feb 12, 2013 | 07:01 PM
ukrkoz's Avatar
Information>Telephone>Settings>Phone Book>Delete All> BINGO.
Old Feb 12, 2013 | 09:15 PM
GeorgiaHybrid's Avatar
Read your manual for the "forget" procedure. As far as the battery goes, if you disconnect a terminal, disconnect the negative, not the positive one. The negative terminal can be disconnected without regard to short circuits.
Anytime you remove a battery, remove the negative first and connect it last.
Old Feb 17, 2013 | 07:03 PM
Pete4's Avatar
If I was going to erase things, I would probably try the radio fuse instead, probably simpler than disconnecting battery albeit some things may be in more permanent memory and factory reset may be required anyhow. For example navigation points may possibly survive power outage and you may not want to have your home location still showing on the map of future owner.
ukrkoz
Jan 24, 2016 08:27 AM
Bill Winney
Nov 5, 2015 12:33 PM
mppkll
Sep 25, 2008 03:07 PM
lifespeed
Sep 3, 2008 06:23 PM
mayall
Apr 18, 2007 11:56 AM
