Electric Vehicle Forums
-   Toyota Camry Hybrid (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/)
-   -   Poor AM reception (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/poor-am-reception-13400/)
rjivey May 2, 2007 09:56 AM
Poor AM reception
Hello all,
Does anyone here have a problem with their AM radio reception?(I know, who uses their Am radio at all:P)
I can pick up stations fine at a full stop or in e-mode, but as soon as the ICE kicks on, it drowns out the stations I'm listening to with a high pitched whine or whistle like cars in the 70's, when you had to put the noise filter inline with the radio to block the EMI from the plug wires and the alternator.
Anyone else have the same problem?
TKCamry May 2, 2007 10:20 AM
Re: Poor AM reception
No problem with AM radio reception. I'm not getting any interference from the engine or the electric motor. Sounds like your radio installation has a grounding problem.
nash May 2, 2007 11:15 AM
Did you tint your rear window? Metallic tints will cause poor AM radio reception. The antenna is part of the rear window.
Otherwise, there is a problem. I would definitely take it to the dealer and have them check it out.
My TCH has excellent AM (and FM) reception. I often listen to LA stations in San Diego. Never had a problem with any noise, or whine, with the ICE running or not.
tnsig May 3, 2007 08:05 AM
I've noticed that overall reception (both AM and FM) are lacking on the TCH compared to my previous cars. I hear static on some stations in the TCH that used to have strong signals (no static) in my other cars.
Droid13 May 3, 2007 11:54 AM
I listen to AM fairly often, quality is usually just fine. I have gotten the previously documented no-volume issue when using the mode button to switch to AM once, maybe twice. If I recall, that happened when I was pressing the mode button quickly through the choices.
AndyB May 20, 2007 05:25 AM
I get AM interference when the gas engine is running. Shame because that's where my favourite traffic station is.
I'll see if they can fix it come the 1st service.
schmidtj May 20, 2007 03:50 PM
There is a new TSB dealing with poor AM reception. The fix is replacing the radio with an improved version. There are model numbers for the NAV and NonNAV radios. The radios need to be ordered by a dealer through the appropriate (Fujitsu-Ten or Denso) replacement program to apply to the warrantee. Check with your dealer.
TSB AU003-07
May 2,2007
Title:
SOUND DISTORTION ON AM RADIO
Models:
’07 Camry & Camry HV
NOTE:
The parts MUST be ordered through the exchange program to qualify for
warranty coverage.
finbib May 21, 2007 07:55 AM
Has everyone seen this on every AM station they try to listen to, or only a couple of stations?
AndyB May 21, 2007 04:09 PM
Good question as I only listen to 1 am station, I'll try a few others.
AndyB Jun 8, 2007 04:51 AM
The new radio goes in next week, I believe it's being done via this
http://www.tundrasolutions.com/forum...e/icon/pdf.gif AU003-07 SOUND DISTORTION ON AM RADIO
Hopefully it it fixes my problem.
