OBD2...worth getting?
Old Feb 12, 2009 | 11:22 AM
haroldo's Avatar
Default OBD2...worth getting?
One of my other cars (Ford Escort) has the check engine light pop on occassionally. Since it's a PITA to get the car to my local garage, I'm thinking about getting an OBD2 (on board diagnostics) reader.
I am not a mechanic and don't plan on doing any under the hood repairs (other than refilling the washer fluid reservoir), but thought it convenient to know what the problem is.
Does anyone have one? Is it easy to use (for a novice)? Are the codes easily decipherable (is the info on the web)? There is a wide price range, do the $35 ones do the same as the $300 ones?
Thanks!
Old Feb 12, 2009 | 03:07 PM
BigTuna's Avatar
Default Re: OBD2...worth getting?
I've got a "Scangauge" which is certainly handy to have around. In addition to being a code reader the Scangauge can also display 4 gauge functions of your choice (programmable). I can not speak for other code readers.
The Scangauge is easy to use, the codes are easily decipherable and there is info on the web.
http://www.amazon.com/ScanGauge-Comp.../dp/B000AAMY86
http://www.scangauge.com/
The ScanGauge II can display up to 4 of 12 possible gauges at one time. The units of measure can be changed and the rate of update can be increased or decreased.
» Fuel Economy
» Fuel Rate
» Battery Voltage
» Coolant Temperature
» Intake Air Temperature
» Engine Speed (RPM)
» Vehicle speed (MPH and KM/H)
» Manifold Pressure
(not available on some vehicles)
» Engine Load
» Throttle Position
» Ignition Timing
» Open/Closed Loop
Scangauge as a OBD2 code scanner:
Scangauge as a multifunction gauge:
http://www.myscantool.com/dtc/specific/ford.html
http://www.trouble-codes.com/
Old Feb 16, 2009 | 01:12 PM
mikieboyblue's Avatar
I like the stock scanguage image....7 MPG @ 129MPH ... that's a solid car.
dabs
Oct 11, 2012 08:29 AM
oldag98
Aug 2, 2012 06:11 PM
cohybrid
Sep 19, 2006 08:41 PM
FallOutBoyx530
Jun 29, 2006 11:04 AM
