Nav power button not working
Old May 6, 2008 | 10:21 AM
ToutSuite's Avatar
Default Nav power button not working
Hi All -
Just curious if anyone else has ever had this problem. The power button on my Nav/Audio system no longer turns the unit on and off. This is the volume control ****, and it still controls the volume fine. I can turn off the audio by holding down the "Mode" button on the steering wheel, and turn off the display by going to the Display menu, but the power button used to shut the whole system down instantly, which was nice. Now it doesn't anymore.
I've recently added a Vais technology SL2i iPod interface, but even disconnecting this doesn't fix the problem.
Anyone ever seen this happen before?
-Alex
Old May 6, 2008 | 01:30 PM
acco20's Avatar
Default Re: Nav power button not working
Originally Posted by ToutSuite
Hi All -
Are you pushing the button in? This is a push in on, push in off button. I am thinking you may have forgotten and are trying to turn it all the way down and off. Just a thought.
-Alex
Old May 6, 2008 | 01:55 PM
ToutSuite's Avatar
Yes, I am pushing it in. As I said, it was working perfectly before, just not now.
Old May 6, 2008 | 02:01 PM
jbollt's Avatar
Pushing my "Power-Volume" button only turns off (toggles off and on) the Audio, not the NAV.
Old May 6, 2008 | 05:04 PM
ToutSuite's Avatar
I couldn't remember if it did both. Currently it's doing neither, but I guess holding down the Mode button does the same thing, then? I just remember there used to be this screen that came up with a CD background image that said "Audio off." Am I remembering correctly?
Old May 6, 2008 | 05:10 PM
jbollt's Avatar
Yes, I get a message that says Audio OFF, with the NAV screen (map) in the background. It seems that your power-volume button isn't working correctly, if it doesn't turn off the Audio portion.
I can't see how the addition of the ipod decvice would make this function differently, but I suppose it is possible. Perhaps the power to the NAV and the Audio are different in the stock mode, and when they installed the ipod device they changed that? Just a wild guess.
abramj
Apr 29, 2015 09:52 AM
John Buttino
Aug 26, 2013 08:44 PM
KimikoPi
Mar 28, 2010 11:29 AM
MrBond
Jul 19, 2006 01:09 PM
quasar666
Oct 26, 2005 12:54 AM
