Motorola Razr Bluetooth Question...
Old Mar 6, 2007 | 12:53 PM
WIRELESS's Avatar
Default Motorola Razr Bluetooth Question...
I am looking at a new 2yr contract with Cingular and have found that the new Razr V3xx has all the options I'm looking for. Does anybody have this phone, and if so, are there any issues with pairing it up with the TCH?
Old Mar 6, 2007 | 01:41 PM
tnsig's Avatar
Default Re: Motorola Razr Bluetooth Question...
Check this website out. It give you information about phone compatibility with Toyota's bluetooth system http://toyota.letstalk.com/brands/toyota-bt/home.htm
Old Mar 6, 2007 | 03:27 PM
WIRELESS's Avatar
Thanks Tnsig, I had printed out the "Quick Guide" for the Razr already, but I wondered if anybody has paired this particular model, ie: V3xx; as it is not listed on the Toyota Bluetooth Website.
Old Mar 6, 2007 | 04:07 PM
agentkev's Avatar
I've got a Motorola Razr v3m through Alltel. It works flawlessly in my Toyota Camry Hybrid. The only downside was transferring phonebook entries one-at-a-time. It works so well that the moment the car "starts", the nav screen shows "Bluetooth connection successful." I don't have to do anything.
Old Mar 6, 2007 | 04:08 PM
warehouse's Avatar
I have the regular V3 (don't know what the V3xx is) and it pairs with no problems. I set up a shortcut on the phone to easily turn the BT on and off. I have found that the quality is pretty good. The only pain is that my V3 won't allow to transfer the whole phone book to the car. You have to do it one at a time. I imagine that the V3xx would have the same functionality if not better.
Old Mar 6, 2007 | 06:08 PM
Paulgw's Avatar
[quote=............. I set up a shortcut on the phone to easily turn the BT on and off.
I have this phone and as you say it works fine with Toyotas blue tooth. Can you explain how you set up the blue tooth short cut, I would like to do the same?
Thx
Old Mar 7, 2007 | 01:11 PM
KC Rusty's Avatar
Both my wife and I use this phone with no issues. Pairs up great everytime - even when my phone is upstairs and the car is in the garage.. (works until I back out of the house)
Old Mar 7, 2007 | 05:23 PM
warehouse's Avatar
This works for my Cingular model phone but not be the same sequence for a T-mobile/Verizon RAZR. They should have a similar function but you might have to break out the manual. To set up a short cut...go to the bluetooth_menu-->settings-->Power:On/off
When you get to this menu hit "change" button and you'll get the sub menu which will allow you to select "on" or "off". Highlight "on" but don't select it. With the "on" highlighted, press and hold the center top key. It will then ask you if you want to assign a shortcut key. Press yes and then select which button you want to assign it to. I selected the "1" key. I then went trough the same procedure to set the "off" value to the "2" key.
To use the shortcut I just quickly press the top/center key followed by the "1" to turn on BT and the top/center key followed by the "2" to turn it off. It's quick and easy and that way I don't have to leave the BT on all the time draining my battery and providing cleaver thieves an opportunity to steal my phone book.
One thing I have noticed is that if do the shortcut and then close the phone before it connects it seems to stop the connection process. If I wait until it's connected I can then close the phone and maintain the connection.
Old Mar 7, 2007 | 06:20 PM
Bigsk8r's Avatar
WIRELESS,
I have a Verizon RAZR V3M. My Bluetooth works so well that people have acted astonished when a noise happens in the background and I explain that I am on Bluetooth.
In the Nav display I set the microphone gain +1 and the speaker gain -1. It sounds sweet.
Larry
Old Mar 7, 2007 | 06:28 PM
tnsig's Avatar
Originally Posted by Bigsk8r
WIRELESS,
Larry
I also set my mic gain to +1. What did setting the speaker gain to -1 do that turning down the volume wouldn't do?
