More info on the TCH's CVT?
Old 06-28-2006, 03:51 PM
spiff72's Avatar
Default More info on the TCH's CVT?
Does anyone out there know of a link on how the continuously variable tranny on the TCH works? I am familiar with older CVT's that used a semi-rigid belt, but I don't think this one works that way. Does anyone know anything about this?
Thanks!
Old 06-28-2006, 04:10 PM
lakedude's Avatar
Default Re: More info on the TCH's CVT?
Does this help?
http://john1701a.com/prius/presentat...ntation_01.htm
It is actually for the Prius but the systems should be similar....
vioarc's Avatar
it's just a car...
Here's a link:
http://www.hybridsynergydrive.com/en...it_device.html
It's continuously variable, but is it technically a transmission if it does not change gear ratios?
Old 06-28-2006, 04:12 PM
lakedude's Avatar
I was looking for Graham's site but the links don't seem to work. Graham's site was an awesome resource for understanding HSD. Anybody know what is up with that?
Old 06-28-2006, 04:31 PM
lakedude's Avatar
Ha! Found it:
Start here and click on "understanding":
http://www.ecrostech.com/prius/original/PriusFrames.htm
Old 06-28-2006, 04:43 PM
TKCamry's Avatar
2007 Toyota Camry Hybrid
Thanks!
See these 3 links to understand how Toyota's CVT is different than a traditional CVT.
http://en.wikipedia.org/wiki/Continu...e_transmission
http://en.wikipedia.org/wiki/Hybrid_Synergy_Drive
http://www.ecrostech.com/prius/origi...ansmission.htm
Electronically-controlled CVT
The E-CVT saw first commercial automotive use in Toyota's Hybrid Synergy Drive system. This system is not a true CVT, having a fixed gear ratio, but behaves very similar to a true CVT. In this system, the transmission is an integral part of the hybrid powertrain and is actually a torque combiner. The gear train is a permanently-engaged, fixed-ratio, 3-way planetary gear. The engine is attached to one input, the driveshaft and the main electric motor to another, and then a smaller motor-generator controls the differential's third input to create a continuously-variable ratio between engine speed and wheel speed, with the variation taken by the electric motor and generator.
The advantage of the system is its mechanical simplicity - no clutches, torque converters or shifting gears. A disadvantage is that continuous electrical power transmission between the two motor-generators is needed even during cruise, with resulting conversion losses, but the total effect is to increase the net efficiency through four methods:
The ICE engine may be completely shut down, rather than idle.
The electric motor operates during high torque demands required to put the vehicle in motion.
The ICE engine operates mostly at higher power demands, where it is more efficient.
Energy may be recovered through the generation function when the vehicle is slowing or coasting downhill, with the energy (stored in the battery) applied to the initial acceleration of the vehicle and when high power demands require a that both the ICE engine and the electric motor operate.
The design of the system may be optimized for efficiency or for performance, as appropriate for the marketing segment for which the vehicle is targeted.
Old 06-28-2006, 05:18 PM
spiff72's Avatar
Great posts guys (and/or girls)! And so fast, too!
Graham's site explains the CVT perfectly. I will have to bookmark that site for future reference!
Curated Content Editor
12-20-2012 05:11 AM
Bobs Metallic Pearl
Honda Insight
01-18-2009 07:26 PM
UWAdventurer
11-30-2008 04:28 PM
schmidtj
12-10-2006 02:38 AM
EricGo
09-01-2005 06:09 PM
Quick Reply: More info on the TCH's CVT?
