Miles to empty
I am on my first tank of gas and doing good. I am at 1/4 of a tank but my miles to empty says 55. My average now is 35 mpg. Something does not compute. Is the needle going to start rapidly dropping after 1/4?
I disregard miles to empty as an absolute, it usually includes a safe buffer. On all of my last cars I have found that I can usually assume miles to empty then I still have 1-2 gallons beyond that. My TL said 4 miles to empty once and the low fule light was on for a bit and I filled up and still had about 3 gallans in the tank. I assume the number is a calculation based on the tank average and the more recent MPG weighed, but again they leave you a buffer.
Guest
Posts: n/a
Most posters that have let their TCH get to empty (myself included) have noticed that there is 3 gallons reserve even after the miles to empty reading says "0". By stupidity I drove 10 miles on vacation after the "0" mark and took 15 gallons to fill up. Several posters (look at old threads or edmunds forums) and you'll see this discussed.
I don't recommend the practice of running on empty but it's not imperative that you worry about filling up when your TCH hits the quarter mark.
Guest
Posts: n/a
It's been two months ago and only once, but if I rember right (and there are other posts on this) when it gets down to a point where the light comes on it may drop the miles to empty number. However I remember it getting to zero so I think I pushed one of the buttons to make the numbers reappear (getting me to zero).
I didn't plan on doing it but it happened and I was sure glad the reserve was there., although I find it a little frustrating that I'd like being able to get to 600 miles on a tank without getting below the ) to empty mark.
Perhaps some of the folks who intentionally tested this can give the specifics.
Originally Posted by FL07THC
So will it say 0 miles to empty before my needle reaches E?
Guest
Posts: n/a
My gage has been consistant in it's decline towards "E" with no sudden drops. When it approaches E, the light comes on warning of low fuel and if I remember right it's pretty close to the E mark about the same time the cruising range is at "0". The "reserve" is gas that is "below" the E mark. It's just there with no visible way of knowing other than when you fill up.
I didn't believe for sure that the tank was 17+ until some other posters intentionally ran their TCH dry. I'm not going to do that but at least two others have done it to prove they can get the 17+ gallons in an empty tank and that's good enought for me to feel comfortable. I've never had to go much over 15 gallons on a fill.
I don't typically wait that long anyway to fill up, but I've noticed many on the milage database do indeed go towards 600 miles before fillup. Probably more of a conversation maker than a hatred for stopping for gas??? It is pretty coll I guess to tell your friends you just drove 1800 miles on three tanks of gas. And then tell them it's only a 17 gallon tank!
I get about 100 miles from 1/4 to E. The miles to empty hits 0 about the same time as the gas gauge hits E. I find if I fill up at E, it will take about ~ 14.5 gallons. The gauge smoothly drops to E, and goes a bit below E if you keep going past 0 miles to empty.
This last tank I drove 713 miles, about 63 miles past E. It took 16.2 gallons to fill up, for a 44mpg tank
Driving into work this morning my miles to empty was below 40 and my gauge is closer to E than to 1/4 tank. I want to drive one tank where the miles to go indicator drops below 0. From what I've seen on this board there should still be about 3 gallons left, so I'm not worried about running the tank dry.
