Hill Start Control Works!
Old Aug 23, 2006 | 09:29 AM
Droid13's Avatar
HSD Organic Interface
Thumbs up Hill Start Control Works!
I finally had the opportunity to try the hill start control function of HSD. I was coming out of an underground parking garage that had a very steep entrance up to the street. There was a line up a cars leaving so that meant having to stop right in the middle of this fairly steep incline. I knew the car had this feature so I gave it a test. I let my foot off the brake and paused for a second or two and the TCH didn't budge until I applied the accel. pedal.
This incline was steep enough that any car without some sort of "hill hold" system would require the driver to be very quick and alert to avoid falling back into the car behind. A succesful test.
Old Aug 23, 2006 | 09:56 AM
jbollt's Avatar
Default Re: Hill Start Control Works!
Originally Posted by Droid13
.... I let my foot off the brake and paused for a second or two and the TCH didn't budge ....
Please explain further. You just took your foot of the brake pedal while stopped on a steep up-hill, and the car didn't roll back?
Old Aug 23, 2006 | 10:10 AM
Droid13's Avatar
Here's a link to the description of the system.
http://www.hybridsynergydrive.com/en...t_control.html
Lilarienne's Avatar
Would this be part of the stability & traction control system?
Old Aug 23, 2006 | 10:28 AM
jbollt's Avatar
wow! Even more tech wonders! This car is simply amazing! (well, not that simple afterall!) Thanks for the tip, Andy!
Old Aug 23, 2006 | 10:52 AM
Orcrone's Avatar
Excuse my ignorance (there's a lot to excuse). I've driven manual transmissions where that would be a problem. But I don't think I've driven an automatic that would go backwards when in Drive. I would think that would harm the transmission. What am I missing?
Old Aug 23, 2006 | 11:09 AM
bruceha_2000's Avatar
Interesting. There is a 'feature' in the 2004 Prius referred to as 'creep'. Austensibly so people wouldn't freak if they took their foot off the brake and the car didn't move forward (on a flat) as they would expect from any other automatic. If there is a balance of 'idle creep' and hill slope, it won't roll back. No different than any other automatic. The link shows a Prius and the 'hill holder' concept seems to generic to HSD. My '04 has slope sensors so maybe this is an improvement for the '06 (maybe '05, don't know) HSD. Another cause for '06 Prius vs '04 envy
Subaru has a "hill holding clutch". The brakes will stay on when you remove your foot until you start to release the clutch. Very helpful on hills. I needed to use the hand parking brake in my manual '86 Mazda for steep slopes.
Old Aug 23, 2006 | 11:22 AM
Droid13's Avatar
An automatic in "D" can still roll backward at idle on a slope.
Old Aug 23, 2006 | 11:34 AM
Orcrone's Avatar
I didn't realize that, but there are no hills here so I guess I'm excused.
Old Aug 23, 2006 | 01:35 PM
Lilarienne's Avatar
This was a big problem for my 99 Corolla on very steep hills. Of course, it wouldn't be as much of a concern if people would not tailgate other people, especially on hills. I mean, if I can see the guy's uvula when he yawns in my rearview mirror then he's probably WAY too close to me....
