Headlights staying on too long for me!
Does this bother anyone else? I've never had a car that the headlights remainded on after the car has been shut off. I read from the manual that the dealer can modify the time the lights will remain on. Has anyone else had the timing dropped to 10 seconds or even 0?
There is just something unnatural about walking away from your car with the headlighs still blazing. I'm always double checking that they actually go off.
I was playing with the gadgets in my car the other night and had the headlights in automatic mode. I shut the engine down and just sat in the car for 5 minutes and the headlights never did shut off. Finally I shut them off manually and then set the switch back to automatic mode again (they stayed off).. I suppose it monitors the doors to see if they have been opened/shut before it trips the timer but I still did not like the way they operated.
Another oddity is the Map lights. Someone else posted that the Map lights will automatically shut themselves off after being left on for a period of time. Last week this was not the case as I was - again - playing with gadgets and had the map light on. Gave it up for the night and went in the house. My son came home a few hours later and informed me that my map light was on! Well - I shut them off but wondered where this "automatic" feature was and if it was somehow disabled on my TCH.
Originally Posted by Big-Foot
You and me both...
As for the map lights, they do not go off on our Sienna either. I believe the 'Battery Saver' feature is only for headlights left on in manual mode.
We have a Honda, and everything turns itself off after 5 minutes. Unfortunately, Toyota seems to be way behind in common sense features!
Originally Posted by flopshot
Covered in earlier threads.
The times the dealer can set this to are 30 sec (default), 60 secs, or 90 secs.
I also find it unnerving that they stay on, and will ask my dealer to change this to OFF the next time I am there.
Yup, OFF means they go off immediately, but I'm not sure if this is when the ignition goes off, or when the doors are locked. I'm guessing it's when the doors are locked.
Originally Posted by nash
Nifty feature - hit the lock button twice on your key fob after exiting the TCH and the lights go out immediately.
I like the headlights staying on long enough for me (or my wife) to enter the house and lock the front door. Thank's Toyota for this feature.
Ed Blown Vert
28
Nov 28, 2009 08:00 PM
JOE540CI
Toyota Highlander Hybrid
Oct 24, 2005 06:30 AM
