HD radio for TCH?
HD radio for TCH?
Does anyone know if HD radio can be added to the TCH and is it worth the trouble? I would like to keep the dash as normal as possible to the factory setup.
I've heard about HD but don't really know anything about HD. I have a non-Nav TCH.
Re: HD radio for TCH?
There is currently no OEM or aftermarket plug-in for the factory JBL system (that I know of) to accept HD radio signal.
You can always install any aftermarket headunit you want, including any HD-capable head unit. You just have to buy the Scosche adaptor for the JBL amplifier. You would also have to purchase the steering wheel controller if available. And you would lose the use of your steering wheel Bluetooth controls.
Thanks for the info Flopshot. No I didn't really know what HD was.
I'm sure the wife would not appreciate losing the Bluetooth, steering controls, etc. I'm sure that would put me in the doghouse!
Thanks for your expertise.
Actually... I don't want to step on any toes, but there is an HD Radio option.
If you have a NAV system, you can use these two devices...
Peripheral Media Gateway
Peripheral HD Radio Tuner
One will add an iPod interface, as well as a second port for HD Radio. The other is the actual HD Radio tuner.
This conflicts with Sirius and XM tuners, as they use the SAT input and controls to operate the HD Tuner and the ipod
Installation Details for your 2007 Camry Hybrid
» Adapter plugs into the factory radio.
» Factory radio must not be Pioneer Premium with multi-color display.
» If you have the factory satellite radio option, it will no longer work with this adapter.
» The Crutchfield MasterSheet, if available, does not cover OEM integration.
» The factory radio must have an "AM/SAT" button.
» Vehicle must NOT have the factory navigation system.
So I would have to say that it works only if you have the non-Nav system.
From the manufacture Page:
# Toyota/Lexus/Scion:
* Overall Toyota/Lexus/Scion compatibility notes:
o Radio must be equipped with a button labeled "AM/SAT” on the face of the radio to be compatible
o Not compatible in Lexus vehicles equipped with a factory navigation style radio with factory satellite installed. The satellite receiver will have to be disconnected at the satellite tuner location in order for the PXAMG to work correctly
o Radios with a diversity antenna will need to make a small modification to the OEM radios main power harness in order for the HD tuner to work correctly. Please refer to included tech brief with inside the PGHTY1 harness packaging. Diversity antenna systems are identifiable by having two antenna connections to the OEM radio.
o Not compatible in Scion vehicles with the OEM option Pioneer radios with OEL display
* Vehicle specific Toyota/Lexus/Scion compatibility notes:
o Not compatible in the Toyota Prius with factory satellite installed. The satellite receiver will have to be disconnected at the satellite tuner location in order for the PXAMG to work correctly.
o Not compatible in the 2009 Corolla with radios that have an “XM” logo printed on the face of the radio. These radios have an internal satellite tuner and are not compatible; All other radios without the logo and have an AM/SAT button are compatible.
One thing that HD (digital) radio most certainly is not is "CD-quality sound over FM broadcast." It's not possible to achieve CD-quality sound in such a narrow transmission bandwidth. This is on a par with advertising heavily-compressed MP3 files or satellite radio as being "CD-quality," or upconverted DVD movies as being "almost HD quality."
Stan
Stan
You realize what HD-radio is, right? For anyone that doesn't, it is CD-quality sound over FM broadcast. Before you do anything, you should find out if your favorite FM radio stations are even broadcasting in HD yet. There are very few stations doing this outside of the major metro-cities. Lastly, HD-radio is not the same as RDS, which the factory NAV system is capable of displaying but the non-NAV JBL is not.
subliminal_wal
02-15-2010 04:22 PM
