Fumoto Oil Drain Valve
A while ago several members posted information about using the Fumoto oil drain valve.
I'm considering installing such, and would appreciate feedback from those who've installed and used - as to benefits and any problems. - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Originally Posted by mikieboyblue https://www.greenhybrid.com/discuss/...s/viewpost.gif What size quick oil drain valve do we use? 12mm? http://www.quickoildrainvalve.com/Se...ts.asp?Cat=187 That is the one I got for my 2007 TCH. This is the reply I got back from them when I initially asked them what I needed since their "catalog" didn't have an entry for the Camry Hybrid at the time: Quote: Thank you for your inquiry of Sept. 29. Our part # F103 (size 12mm-1.25) is a suitable application for 2007 Toyota Camry Hybrid. Regards, YM International Company On-line Distributor of Fumoto Oil Drain Valve www.fumotovalve.com |
Re: Fumoto Oil Drain Valve
I have used them for years with no problems.
Put one on the TCH last week, I highly recommend them. Regards, habu968 |
I've been using mine for almost two years and about four oil changes. It works quite well although I offer a few points on interest:
Now if only removing the filter was a bit less messy.... :( |
The only comment I will make is to ask mechanics around your area if they use one.
Why would a mechanic spend $25 to put one on a customers car?
That makes no sense...............:confused: |
Read down the page on this link as far as endorsements. Also note that it is being installed at the factory on some heavy duty trucks. The point is that it makes it easier to change your oil at home. Please research and understand before you make comments condemning a product..........particularly one you have never used.
http://www.quickoildrainvalve.com/ |
habu,
I have never met a mechanic that had one on HIS car. If a customer wants one, they will put it on. I HAVE tried them. It takes too long to drain, has a tendacy to seep oil and might, and I mean might, make things easier for a DIY'er. How difficult is it to remove one bolt and then tighten one bolt? |
Originally Posted by GeorgiaHybrid
(Post 201107)
habu,
Michael,
That makes sense. I have been working on cars for so long I don't think about it. If I do, I just slip on some nitrile gloves and have at it. It only takes 15 minutes to change the oil, check the tires and everything under the hood so I never could understand why it was "faster". |
(Post 201134)
Michael,
That makes sense. I have been working on cars for so long I don't think about it. If I do, I just slip on some nitrile gloves and have at it. It only takes 15 minutes to change the oil, check the tires and everything under the hood so I never could understand why it was "faster". I probably wont get one on my future car. I figure, I have this one, might as well use it. Although, if they improved the flow, it would be well worth it. |
