fuel consuption
I have a 2007 camry hybrid. I am in toronto, ontario. Im currently at 28,000 km. and im averaging around 700 km to a tank. I never go right to empty, usually fill up at 50 litres. Just wanted to know if thats average.
thanks
thanks
That would be 430 miles when you fill up. I fill my tank between 400 and 500 miles. Thats usually when its down to 1/4 tank on the fuel gauge. You did not include your miles per gallon from your readout.
At 17,500 miles you engine is broke-in and should give you good miles per gallon other than the cold weather where you live.
After filling up, the range to empty is a quick and easy indicator of your general fuel consumption because it is averaged over a longer period then then "Tank Ave" display which is just the current tank. After fillup, right now mine is showing about 920km range. I expect it will start dropping now that the colder weather is knocking.
If I could rate myself from 1 to 10 (1 being drive the stink out of the car, 5 being casual driving, and 10 being conserving every ml of gasoline), I would rate myself usually 7 or 8 depending on the day.
ricko2
High Mileage Vehicles
06-29-2011 10:47 PM
Jason
Hybrid & Related News
05-10-2008 10:29 AM
