Fuel brands, ethanol & mpg
Old Nov 12, 2008 | 06:36 AM
vioarc's Avatar
it's just a car...
Default Fuel brands, ethanol & mpg
I've always used Shell regular in my TCH because it's convenient.
I noted the "contains up to 10% ethanol" sticker on the pump, but didn't think much about it.
After reading a post here suggesting ethanol may reduce MPG, I'm considering switching to a brand that has no ethanol.
Which brands are ethanol-free?
Should I expect higher MPG?
Old Nov 12, 2008 | 07:43 AM
GeorgiaHybrid's Avatar
Default Re: Fuel brands, ethanol & mpg
Gary,
It depends on the state. Some require the use of ethanol in gasoline and others do not. Georgia does not require it but the owners of the stations can choose to add ethanol to the gasoline they sell. Most of them started adding ethanol when gas went to $4.00 per gallon and the ethanol cost was roughly one half of that.
One lone Chevron in my town still sells (and advertises) 100% gasoline. I now buy from them as the price difference (3% right now) is more than offset by the mileage improvement.
Old Nov 12, 2008 | 10:31 AM
mikieboyblue's Avatar
I truey believe ethanol reduces effective MPG. In my TCH and in my previous vehicle, I would notice about 10% less MPG when using gas containing 10% ethanol.
In New York State you used to be able to get 100% gasoline part of the year and then 90% gasoline / 10% ethanol in the other part of year. However, this has now changed so that the mix is always 90/10%.
My average MPG is about 36 in the summer months while in NYS. When I traveled south and was able to get 100% gasoline, my MPG was consistently 38 - 40 (no I did not change my driving habits and VA, NC, and SC are still pretty hilly areas).
But oh well....
I usually get Sunoco fuel as it seems to be the best in town but sometimes I go to a cheaper 7-11. Interestingly, they just opened a Shell across the street from where I live. It used to be a Mobile.
Old Nov 16, 2008 | 12:03 PM
JoeRemix's Avatar
There have been threads on this subject before. Fuel economy is affected more strongly by the detergents (additives) that various companies use in their gasoline. All companies are required to use a minimum amount, but stations that are "Top Tier Gas" stations use a better package than "cheap" gas.
Check out www.toptiergas.com
I have experienced a boost in FE when I switched to gas from Top Tier stations exclusively. I used to use the cheapest (Sam's Club, Costco, Sheetz, etc.).
Old Nov 17, 2008 | 06:36 AM
SnottyW's Avatar
Here is a snip out of the Top Tier rules...one that I'm not fond of.
1. Contain enough denatured ethanol such that the actual ethanol content is no less than 8.0 and no more than 10.0 volume percent.
Old Nov 17, 2008 | 08:25 AM
With that in mind, new vehicles should be capable of adjusting whatever is needed to make up for that correct?
My old vehicle's mpg dropped severely when stations switch to ethanol from a non-ethanol blend. I have not been able to see the impact much with the TCH because all stations in my area run 10% ethanol year round.
UWAdventurer
Nov 13, 2021 12:01 PM
HyCAMBill
Apr 4, 2008 01:55 PM
bookwitch
Oct 20, 2005 09:30 AM
kpez019
Toyota Highlander Hybrid
Oct 13, 2005 12:42 PM
Jason
Aug 10, 2004 09:53 AM
