Front window defoster and ECO
Why can't I use the front window defroster and ECO mode at the same time?? I'm not even talking about the special button for front window defrost. I just want to set the mode button on defrost, but it always turns off the ECO button and I can't turn it back on.
No, because I just am setting the mode to defrost, so the air is coming out of the windshield area, instead of coming out the front vents. I'm not pushing the designated "front window defrost" button. Also, I can't turn the ECO back on in that mode. I push the button and nothing happens.
How do you set the mode to "defrost" without actually pressing the front defrost button?
I mean, if it's blow onto the windshield, it's most likely because you want to clear the windshield.
If you didn't want it blowing in your face, you would've chosen face/foot or foot only.
interesting. To defog, you need the A/C anyway cause it acts as a dehumidifier so you can blow dry air onto the windshield.
