Front Right Creak - Bushings or Body Cowl
Old Apr 24, 2010 | 05:58 PM
gh88888888's Avatar
Default Front Right Creak - Bushings or Body Cowl
Experiencing a quiet creak (not rattle or squeak) from the front passengers side occasionally while moving from stop, coming to a stop, turns and bumps. Jacked up the right side and inspected the wheel area and underbody -- couldn't find anything superficially wrong. Has anyone experienced a similar noise?
I found two toyota bulletins that may match this symptom: Stabilizer bar bushings (posted here by SPL) and a Body cowl/fender creak (google search). Has anyone done the Body cowl TSB?
Is there any way for me to inspect the bushings? The bulletin says its a lubrication problem, could I just try to apply some high temperature grease to the bushing?
The Body cowl and fender creak seems impossible to verify without some disassembly. The fix would require re-do welding and then using a crow bar to separate the cowl from the inner fender.
Old Apr 24, 2010 | 06:05 PM
gh88888888's Avatar
Default Re: Front Right Creak - Bushings or Body Cowl
Body Cowl and Fender Creak
T-SB-0055-09
January 30, 2009
2007-2008 Camry, Camry HV
http://www.toyotapartsandservice.com...S/T-SB-0055-09 n.pdf
Old Apr 24, 2010 | 08:28 PM
Mendel Leisk's Avatar
Google this:
T-SB-0055-09n.pdf
(link keeps truncating)
UWAdventurer
Apr 13, 2014 09:43 PM
stevedebi
Feb 15, 2012 06:57 PM
AlanWBaker
Aug 17, 2011 08:10 PM
Dmchal2
Apr 24, 2009 09:41 PM
fullofbeans
Mar 20, 2008 08:39 AM
