Engine block heater kaput
Old Mar 4, 2012 | 09:07 AM
jpezz's Avatar
2009TCH w/NAV bought 4/08
Thumbs down Engine block heater kaput
I bought an engine block heater a few years ago and had my mechanic install it (I'm too old and fat to be working on cars anymore). Well this winter I discovered it wasn't heating. With a power meter I verified that no current was flowing. With an ohmmeter I verified that the resistance was infinite (should be about 40-50 ohms to get 300W). Also infinite between ground connector and the engine block (I assume the heater is grounded to that wire so you don't end up with a car that is "hot" [pardon the pun] if the "hot" wire becomes loose and touches the engine.
Sounds to me like the connection is completely broken rather than a burnt out heater.
Other than pulling it out and replacing it, any suggestions?
Considering I'd have to pay to have a new one put it, it is probably not worth the expense. I'm looking at getting a replacement for my old pickup - likely a leaf or plug-in hybrid for short trips and keep this car for the long distance stuff. So it would sit a lot more vs now being used all the time.
Old Mar 4, 2012 | 10:12 AM
wwest's Avatar
Default Re: Engine block heater kaput
Many block heaters have an in-line thermostat so no wattage is used unless the OAT is below some set outside temperature, often 35F.
Old Mar 4, 2012 | 04:03 PM
rburt07's Avatar
You might chance cutting off the wires where they bend a lot a few inches behind the plug. I once found thats where I had a open wire. I carefully stripped all 3 then put on a yellow plug with the ground from walmart. It's worked ever since.
I once called a north dakota dealer and the parts man gave me a parts number for my local dealer to order. It shows the 30 something ohms anytime I look at it with the ohm-meter. I was once told the new car model block heaters would not work unless the temperature was less than freezing. To me that would be bummer. A warmer engine when it's 32 degrees is nice and still saves money for mpg. I bought mine a few years before I ever read that.
Old Mar 5, 2012 | 08:46 AM
wwest's Avatar
They probably meant 0 Centigrade. Block heaters are made primary for extreme cold, MT, AK, etc, climates but only to keep the engine warmed up for easier starting.
Old Mar 5, 2012 | 12:38 PM
rburt07's Avatar
That sounds correct, 32 degrees or 0 centigrade. It was many years ago the parts man told me that so it's easy for this old man to forget.
Old Mar 5, 2012 | 06:42 PM
jpezz's Avatar
Not with the Toyota engine block heater. You plug it in - it works even if the temperature is 70 degrees.
Old Mar 6, 2012 | 03:39 AM
rburt07's Avatar
I forgot to mention my block heater works no matter what the outside temperature. I just passed along what was told to me by some toyota parts man in Fargo North Dakota.
gc77584
Jan 9, 2020 04:20 PM
subdewd
Jan 15, 2011 05:12 PM
RIHCH
Nov 24, 2008 05:54 PM
ranger01
Sep 11, 2008 12:17 PM
efusco
Toyota Highlander Hybrid
Mar 22, 2006 11:47 AM
