Electric Mode Range
![Question](https://electricvehicleforums.com/forums/images/icons/icon5.gif)
I'm curious about how far you can drive in the electric mode with no hills.
Where I live it is hard to find very flat areas that go for any distance. It appears to me from my limited testing that you can drive about 2 miles in the all electric mode.
For those of you who live where it is flat, how far have you been able to travel without using the ICE?
I drove on a flat road in electric for 4 miles. I think the secret was the speed limit dropped from 40 to 35 to 25 along the route (was I cheating?) When the speed limit went back up and I sped up, the ICE came on.
It really varies a lot with the SOC when you start going in EV mode, the speed you maintain, and obviously if you are gaining or loosing altitude along the way.
That said, going home, I if I hit a light at the bottom of a small hill green, I can go 1 1/2 miles on EV mode doing 35 - 40 mpg, going up a very slight grade, before turning on to my street and parking. SOC usually drops to 3 or 4 bars by the time I park.
I-15 North climbs a small hill after Ted Williams Parkway in Poway. I often hit 5 to 30mph slow and go traffic in this area, and easily go 4 miles in EV gaining SOC as the freeway gently goes down a few hills.
Regardless of the EV range, I greatly enjoy getting gas in my TCH at the station at the top of the hill and then driving away in electric mode for about 1/2 mile. For that distance, the display will say I'm getting 99.9 MPG for the tank. Man, I'm good.
![Wink](https://electricvehicleforums.com/forums/images/smilies/emotikons/wink.gif)
How do you manage increase your speed from 5 to 30 mph in slow and go trafic?
For me if engine warm enough, I can increase speed from 5 to 15 mph most in all electric mode.
I also have another question.
When ICE starts after all EV mode, I usually accelerate quickly to little more than desired speed and give up gas for fraction of second and than try to go in all EV mode. (yes, usualy Pulse and Glide technique) Is this is the only way to keep on returning to all EV mode and shut ICE off or there is a better way?
![Tongue](https://electricvehicleforums.com/forums/images/smilies/emotikons/tongue.gif)
- The ICE must be warm - temp gauge reading about 1/3 scale or slightly higher, traction battery SOC should be over 2 bars.
- ECO mode helps "encourage" the use of EV mode by making heat/AC climate control a secondary objective. (note Defrost, Min/Max settings disable ECO)
- a) Coasting at speeds between 36 and 42mph for a few seconds will most times put the TCH in EV mode. However, once the ICE restarts, it will stay running until either a) reoccurs or b) happens.
- b) If you stop with the ICE running and warmed up for 7 - 10 seconds, the ICE will stop, AND the TCH sets "hybrid" mode. From this point on, if you start coasting at any speed under 40mph, the TCH enters EV mode quickly (2-3 seconds)
![Teeth](https://electricvehicleforums.com/forums/images/smilies/emotikons/teeth.gif)
You are right, around 40 to 50 KMH, I have seen ICE on. When in idle mode, it is still using gas.
Are you from Canada?
Temp hers in Regina is around 5 degree C in the morning and day time is around 15 to 20. Today morning it was 1 C and is expected to go around 24 C for high.
I am on first tank and I have around 650 KMS on Odo meter and tank is just over 1/4 mark. Display says I should get around 200 KMS more.
If you are in Canada, what mpg you get in winter and summer?
At the end of my first tank, I am going to start a new post describing all the conditions including temp, driving distance, driving speed, number of turns, number of stop signs and lights, road conditions etc and also include all the stats you get in display. Ideally I wouold like all Canadian owners of TCH to respond to this post describing their situation and fuel efficiency.
You can see user location information on the right side of each forum post header (look across right from the user's forum alias name). And yup, I'm just to the east of Toronto right on Lake Ontario. You can set your own location and other info by clicking the small "UserCP" link near the top of the page.
Last summer I typically got tank averages around 6.1 to 6.4, occasionally getting a few good ones in the 5.8 to 6.0 range. Almost all trips got into the 3rd bar scale "Excellent" range, often 3 full bars. Winter temps increased by fuel consumption by 25% up to the high 7s or low 8s for tank averages.
Weather here is similar to you, cool single digit C temps in the morning, nice in the afternoons and is getting better every day. On Saturday I had my first long drive where I could keep the tank average below 6.0 for the first time since last summer.
