ecodrive score below 6l/100 kms
Old Jun 23, 2012 | 07:54 PM
clayton4115's Avatar
Default ecodrive score below 6l/100 kms
hello all, i frequently get "excellent" after I switch off the car and the instaneous fuel economy goes to the third level which is 6l/100 kms however it is possible to show below this level? i.e i may have done 5l/100 kms but it only shows to 6l/100km.
Old Jun 25, 2012 | 06:23 AM
BOFH's Avatar
Default Re: ecodrive score below 6l/100 kms
The display is fixed. No matter how much better you get, it will still just show that 6l/100km.
If you want to know what you are truly getting, get a ScanGuageII.
Old Jun 25, 2012 | 09:22 PM
i do have scangauge2 I just have to install it,
thanks
Old Jun 26, 2012 | 05:34 AM
BOFH's Avatar
Once you install it, calibrate the speed against a GPS. The fuel is self calibrating by using the fillup function.
Old Jun 27, 2012 | 02:40 AM
ok, so i did a few trips with my scangauge, today we had appalling weather, the temps outside were about 57F in rain and wet roads and i managed to get 42mpg and high 30s, i am so impressed with this car, only small gripe is that on the display in which you cycle through it does not have elapsed time, i wish they also had this as they have distance traveled since start.
Old Jun 27, 2012 | 05:17 AM
BOFH's Avatar
You might be able to set it as an xGauge as it does have that function under the 'trip' menus.
Send them an e-mail. It may take a week or so to get a reply though.
Old Jun 27, 2012 | 10:04 AM
Sorry, what is an xgauge?
Old Jun 28, 2012 | 05:21 AM
BOFH's Avatar
On the SG you can program custom gauges. Look in the manual or go to their website...
Old Jul 1, 2012 | 02:26 PM
rburt07's Avatar
The ScanGauge II has a feature called X-gauge. It allows you to manually create a readout not normally already in the gauge. The X-gauge selections are listed on their homepage below and can be added to your SC. I don't think the one for horsepower or traction battery voltage works for the Camry.
http://www.scangauge.com/support/x-gauge-commands/
Old Jul 1, 2012 | 08:26 PM
my scangauge is v3.1 so i will need to post it in to get them to update to 4.10.
