Re: Does your fuel door open when the car is in motion.
Some folks (not all) say they have a hard time distinguishing the eco button from the fuel door button and that they have inadvertently opened the fuel door instead of deactivating the eco mode of the AC.
no for me.
While I've never had a problem discerning the ECO button from the fuel door button, I did have a problem when we first got the TCH in that I would reach down and work the hood release thinking that it was the parking brake release (first time with push-on/push-off)!
I'm more concerned here with the ECO button not having memory. I get tired of having to press it to turn on (I never press it to turn off). That and the recirculate button with the same problem. |
Originally Posted by swhoutx035
(Post 180518)
Originally Posted by talmy
(Post 180756)
...I'm more concerned here with the ECO button not having memory. I get tired of having to press it to turn on (I never press it to turn off). That and the recirculate button with the same problem.
It will turn off if you set the temp to low or turn on the defroster either by button or by cycling through the air flow modes. But it won't turn back on again when you leave the modes. Thus you have to frequently press the ECO button to enter ECO mode. I've never pressed it to leave ECO mode. And you can't tell if you are in ECO mode by feel (in fact you can't hardly use any of the climate controls by feel) -- you must look down and check with your eyes. This is bad design -- you should be able to work every control with your eyes on the road.
Originally Posted by haroldo
(Post 180766)
It might not be the lack of memory, but rather the way it's set up. If the temp is set to "LO", I believe ECO truns off. It, similarly, turns off under other conditions.
(Post 180793)
(Post 180815)
I have mine set to ECO and never have to re-set it. In our 97+ afternoon temps, when I start the car the AC comes on, goes to MAX/Recirc until it reaches the auto-temp set, and then goes back into the auto mode with ECO still being lit up on the AC control display.
In mild weather when you don't want either air conditioning or heating, but you want fresh air and are not in Auto mode, the Recirc turns on automatically anyway. Apparently this can be fixed by the dealer. But at least I have no problems with the fuel door. |
